What tool to chamfer transmission cams?
ivaldes1
First Name: Ignacio
Last Name: Valdes
Post by ivaldes1 » Fri Jan 25, 2019 1:56 pm
Greetings Model T brothers, What tool can I to use chamfer the transmission cams for the o-ring trick? I do not have a lathe. -- IV
Last Name: Strange
Re: What tool to chamfer transmission cams?
Post by CudaMan » Fri Jan 25, 2019 2:01 pm
I would think that a cordless drill and one of these would do the job. :)
https://www.homedepot.com/p/Ryobi-3-4-i ... /205469282
rickd
First Name: Rick
Last Name: Duquette
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring, 1914 Touring, 1925 Touring, 1927 PU, 1955 T Bird, 69 Shelby GT 350
Post by rickd » Fri Jan 25, 2019 4:37 pm
I use a pneumatic die grinder with the fine grit triangular shaped stone. Level the piece in a vise, take your time and test fit often. Not as precise as some machine work I've seen but it gets the job done.
Post by DanTreace » Fri Jan 25, 2019 5:53 pm
Just a stone will do the job, place in your elec. grinder, or a elec. drill would work, although the drill motor will run at a much slower speed.
A stone will jump around less than a cheap conical large tooth cutter tool, unless you have the right speed and lube.
Takes a few minutes to do it. A 1" ball or 3/4" cone abrasive stone, the groove is just half or bit more of the O-ring thickness.
George Andreasen
Last Name: Andreasen
* REQUIRED* Type and Year of Model Ts owned: 0...building from parts
Post by George Andreasen » Fri Jan 25, 2019 6:13 pm
Thanks for the advice on depth Dan. I plan to use this stunt when I rebuild my hog's head, but I've never seen anything on depth.
Post by Scott_Conger » Fri Jan 25, 2019 6:42 pm
This will provide all the info you could ever need regarding stretch, compression and % gland fill: https://www.marcorubber.com/o-ring-groo ... ations.htm
