1926/27 Front Spring Dimensions
Bmettli
Topic author - Posts: 87
- First Name: Brian
- Last Name: Mettling
- * REQUIRED* Type and Year of Model Ts owned: 1922 touring, 1933 Dodge
- Board Member Since: 2013
hi all,
I recently bought a set of front T springs from a swap meet, and I assumed they are 1926/27 because they had 8 leafs. There isn't much in the encyclopedia for measurements, can someone tell me what they measure for spring width and length?
Also, these are not drilled for oilers, so I'm not sure exactly what I have at this point. here's some pics:
just want to make sure these are actually T, I'm told they are not.
thanks!
thanks!
Re: 1926/27 Front Spring Dimensions
8 leaf (late: 1926-27)
Length of Spring Leaf // and Overall Height of Ea. Leaf from flat surface
8-13/16" / 9/16"
11-9/16" / 13/16"
14-13/16" / 1-1/8"
18-5/8" / 1-7/16"
22-5/8" / 1-7/8"
27-1/8" / 2-1/4"
31-5/8" / 2-11/16"
33" / 3-5/16"
Your spring appears to be an aftermarket version, the sharp angle clipped edges are un-like Ford mfg.
8-13/16" / 9/16"
11-9/16" / 13/16"
14-13/16" / 1-1/8"
18-5/8" / 1-7/16"
22-5/8" / 1-7/8"
27-1/8" / 2-1/4"
31-5/8" / 2-11/16"
33" / 3-5/16"
For ref. to the Ford style ends of the leafs, this work by John Regan from the prints of Ford springs. Good way to i.d. Ford parts vs. aftermarket.
cfruoff
- First Name: Carl
- Last Name: Ruoff
- * REQUIRED* Type and Year of Model Ts owned: 1925 Coupe, 1927 Tudor
- Board Member Since: 2011
I believe Model T spring leaves are 1 1/4" wide, at least they are on my model Ts (a '25 Coupe and a '27 Tudor). Model A springs (I own a '29 Tudor) are 1 1/2" wide.
Shouldn't the height of the main leaf be measured from the centers of the spring eyes?
Carl
Carl
Carl
Yes, Model T front springs are 1 /14" wide , rear springs are 2" wide.
Perhaps if making spring leafs, measures are from center of eye, without Ford prints, hard to know.
These measures are easy to use at swap meets, the eyes resting on flat surface, and tape measure up to the center bolt hole
For distance between eyes, (perch mount) measure for the Front springs.
31-5/16" to 31-1/2" 7 or 8 leaf
7-Leaf Front spring, center of eye to center of eye.
rondupree
- First Name: Ronald
- Last Name: Dupree
I cannot tell from your pictures, but an easy way to see that a spring is for a Model T is to look for the oil hole at the spring eye. Model A's, for example, have the oiler built into the shackle so they did not have to have the spring eye drilled for the oiler.
Ron Dupree
Ron Dupree
Ron Dupree
Bmettli
- First Name: Brian
this is all great, thanks you guys
cfruoff
- First Name: Carl
- Last Name: Ruoff
Thanks everyone for the useful information!
--Carl
--Carl
Banjoe
- First Name: Joe
- Last Name: Lucas
What an excellent discussion.
I was trying to sort out front spring confusion and Dan Treace provided a link to this valuable discussion.
Although not what I wanted to hear, it was just what I needed to hear and explains why my front springs are 1 3/4" wide instead of the normal 1 1/2". You also explained why there are oiler holes in the rear spring eyes but none are in the front. Clearly someone has fitted a Model A spring set at some point in this vehicles challenged past. Not sure what they did to the frame to make this wider spring assembly fit so will have to check this out closely and see if things are recoverable.
Thank you all for sharing your wisdom,
Joe
Joe
“We don’t do these things because they are simple, we do them because we thought that they were simple”.
