Steering case position Question
lorenzo26
First Name: lorenzo
Last Name: leon
* REQUIRED* Type and Year of Model Ts owned: 2 doctors coupe
Post by lorenzo26 » Thu Oct 10, 2019 9:45 pm
does the groove go up or down??
First Name: Jeff
Last Name: Humble
Board Member Since: 2006
Re: Steering case position Question
Post by Humblej » Thu Oct 10, 2019 10:00 pm
Up
Post by Scott_Conger » Thu Oct 10, 2019 10:20 pm
Post by Allan » Fri Oct 11, 2019 1:04 am
Figure 395 shows the slot at the top, and that is where it is on three columns I checked. A practical reason for this when rebuilding a column is that is the way the rivet holes will line up, the assemblies seemingly individually fitted. Additionally, the long peg which engages in the slot has a direct relationship to the keyway for the pitman arm.
