what does a KW master vibrator do?
TBones12
Last Name: Poane
* REQUIRED* Type and Year of Model Ts owned: 1916 Hack, 1910 Touring, 1914 Touring, currently a Touring 1912, 1912 Torpedo Roadster
Post by TBones12 » Mon Oct 14, 2019 5:24 pm
I noticed a KW master vibrator for sale and I have seen them before but it has one coil, what does it do?
Thank you in advanced!
Re: what does a KW master vibrator do?
Post by Rich Eagle » Mon Oct 14, 2019 5:40 pm
JohnH
Last Name: Hunter
* REQUIRED* Type and Year of Model Ts owned: 1926 Geelong Tourer
Board Member Since: 2002
Post by JohnH » Mon Oct 14, 2019 7:42 pm
Early coils did not have a cushion spring which made it very difficult to adjust the coils for consistent firing, particularly when operating on magneto.
By using a master vibrator, the contacts in each of the four coils is bypassed, and the single contact in the master vibrator takes over the function. All coils fire the same as each other. Once the cushion spring was introduced, the master vibrator became unnecessary.
Ron Patterson
Post by Ron Patterson » Sat Oct 19, 2019 5:10 pm
Se attached diagrams contrasting a Model T engine with and without a Master Vibrator.
