Anyone want to venture a guess on what this axle is for?
Jeff Perkins
Topic author - Posts: 237
- Last Name: Perkins
See picture, top axle is Model T, bottom looks exactly like a T but shorter. It has not been cut or welded. Is it for a clown car? How about a FWD conversion? Opinions please!
1926 Model T Touring,
1948 Chrysler New Yorker,
Re: Anyone want to venture a guess on what this axle is for?
Most likely shortened on the gear end - pretty simple machining process to shorten & recut the key & keeper slots.
- First Name: Keith
- Last Name: Townsend
I believe some snow machines used narrower axles.
Michael Peternell
- First Name: Michael
- Last Name: Peternell
I'm going to guess for a tractor conversion. Shaw offered different configurations/ Wheel spacings.
HPetrino
- First Name: Henry
- Last Name: Petrino
I've never had one apart, but does a Ruckstell use a shorter axle on one side?
Erik Johnson
- First Name: Erik
- Last Name: Johnson
Jeff Perkins
The Ruckstell uses standard Ford axles on both sides. I would suspect that axle might have been cut down for a speedster or maybe for a small trailer to be pulled by a T.
Rich Bingham
- First Name: Rich
- Last Name: Bingham
Model T rear axles were often modified for application on farm implements. Around here, many one-row spud diggers used them. (Blackfoot, Idaho - world potato capitol -
"Get a horse !"
henryford2
- First Name: Joseph
- Last Name: Andulics
Offset rear axle for sprint car
