Apco Shimmy Stops question
lorenzo26
Topic author - Posts: 50
- First Name: lorenzo
- Last Name: leon
- * REQUIRED* Type and Year of Model Ts owned: 2 doctors coupe
Any one has instructio on installing this
Re: Apco Shimmy Stops question
APCO Shimmy Stops are typically the cause of terrible wear on tie-rod bushings and tie-rod bolts. The moment you think you need them to fix some sort of percieved ill and install them, they go to work wrecking things. This thread mentions them and the masking of wear (and wear they cause)...http://www.mtfca.com/discus/messages/70 ... 1500495117 and here...http://www.mtfca.com/discus/messages/41 ... 1407510383
How they're installed...here: http://www.mtfca.com/discus/messages/25 ... 1355174093
They fix things like a tetanus soaked bandaid protects a cut.
I would advise leaving them as a display item.
Doug Keppler
- First Name: Douglas
- Last Name: Keppler
Scott is correct, a version of those were on my car when I got it and they were wearing a groove in the tie rod. I rebuilt the front end properly and there is no rattling. They are not needed
1924 Touring car
There's No Substitute for Proper Lubrication
lorenzo26
- Last Name: leon
Thank you for the info --wont be using them
