"Ford" script on front frame crossmember
keen25
Topic author - Posts: 108
- First Name: Eric
- Last Name: Keenan
- * REQUIRED* Type and Year of Model Ts owned: 1923 coupe, 1925 TT, 1926 coupe, 1925 Tudor, 1925 pickup, 1926 fordor
I found a Ford Script stamped into the face of the frame's front crossmember, to the right of the crank/spring clamp. It is about 1/2" high. The car is a 1925 model T roadster. Is the unusual or normal?
Re: "Ford" script on front frame crossmember
Normal - there was just a recent discussion regarding the same subject.
I didn’t know either about the Ford script being on the cross member until I started cleaning the frame up on my 1919 Runabout.
Steve Jeff has a pic of a really nice cross member with mint script on an earlier thread. I’ll bet a lot of guys didn’t notice it either until they cleaned up the frame like I did during restoration.
Mark Osterman
- Last Name: Osterman
You mean like this? Now what’s the hole on the right side for?
keen25
- First Name: Eric
- Last Name: Keenan
Yes that is it. I have restored a 25 TT and 26 Coupe ; have never notice. Maybe it is time to see the eye doctor.
Mark O. I wonder if the hole was factory or drilled later for something. I have 3 T’s and they don’t have the hole. At first glacé it looks the hole has been there a long time and factory drilled. Something was mounted there way back when? Hmmmmmm
Mark Osterman
Eric, I never noticed it until the other day when the light “raked” across it just right.
John, Some have though maybe a badge as in an auto club.
The cross member that Steve J may show a picture of has the sharpest, clearest, stamping I have ever seen. I have had and seen many cross members with faint stampings that even scraped and cleaned a bit were barely visible.
