Installing a 1926 Radiator.
Mike Robinson
Topic author - Posts: 89
- First Name: Michael
- Last Name: Robinson
- * REQUIRED* Type and Year of Model Ts owned: 1926 Speedster 1914 Speedster 1925 Touring 1926 roadster pickup
Does any one have a clear view or cutaway showing the proper installation of a radiator on a 1926 T ? I have a Ford manual but the photos aren’t clear as to the correct layout of all the Layers of parts starting with the fenders on up to the crown nut.
John Warren
- Last Name: Warren
Re: Installing a 1926 Radiator.
Thanks to Martyn Vowell
AdminJeff
All of Martyns technical drawings are in our forum gallery. A treasure trove of info! Just click the camera icon that says "Gallery" on the upper right of any page on the forum, or click here:
app.php/gallery/album/5
Jevv
Jevv
John Illinois
- Last Name: Burgett
That is a treasure trove. Bookmarked for future use.
John
John
RustyFords
- First Name: Don
- Last Name: Allen
It wasn’t until I installed my radiator for the first time that I realized that part of the lower thimble’s job is to guide the radiator and shell into position.
1924 Touring
Mike Robinson
Thanks, This makes it much more clear . I will check out the gallery. I didn’t know to look there. Mike Robinson
ArthurB
- First Name: Arthur
- Last Name: Babitz
- * REQUIRED* Type and Year of Model Ts owned: 1927ish Roadster Pickup
Mike, I did this recently on my 1927. If you preload the bottom spring by putting flat stock or washers between the frame and the bottom of the stud, the job is much easier. Otherwise you may not have enough thread showing at the top to start tightening down the nut at the top.
No different that any other high radiator that I can see.
Mike Robinson
Seeing a more clear drawing really helped. The lower thimble didn’t fit the hole drilled in the radiator flange . I had to ream it out. When I got the roadster the hood didn’t fit right . It was sitting up to high. Now I see why. Now everything lines up. Thanks.
George N Lake Ozark
- First Name: George P
- Last Name: Clipner
Just a word of caution. When I changed out my old hardware with new the new springs were too long and stiff. Glad I kept the old ones and used them. cleaned up ,repainted and everything went together like a charm using the old springs.
Mike Robinson
Yes . The new springs were to long. I used the old ones. I also preloaded the bottom spring as suggested. That’s the only way I could get enough thread to start the nut. All good now . Thanks for the help.
You can cheat a little length in the stud by winding the lower nut on just far enough to get the split pin in. Then back the plate off until it binds on the nut. This often means two or the thread coils are left above the plate.
