Question about new tool??
Topic author - Posts: 5552
- Last Name: Hatch
I am think about making a run of 13/32 x 16 taps. I will need to know if there is any interest in these taps? Post here or email me at address in pictures. Thanks Dan
- Attachments
- 49A19A64-D93C-48EE-B3D7-AC782737131B.jpeg (50.1 KiB) Viewed 12887 times
Fire_chief
- First Name: Charlie
- Last Name: Gagel
- * REQUIRED* Type and Year of Model Ts owned: 12 Tourings(2),14 Tourings(2),22Touring,22 TT,21 Fire Truck,14 Chief Car
Re: Question about new tool??
Where were these threads used?
Rear axle clam shell, for the drive shaft roller bearing housing holes. Use the tap to clean the holes for the studs or the later cap screws.
Jeepbone1
- First Name: Brad
- Last Name: Kirtner
- * REQUIRED* Type and Year of Model Ts owned: 1924 Touring Car, 1927 Closed Cab TT, 1927 Coupe
I’ll take one.
Brad
Brad
- Last Name: Hatch
Needing at least 12 orders before I can get info. Dan
Russ T Fender
- First Name: Val
- Last Name: Soupios
I'll also take one.
sweet23
- First Name: Darryl
- Last Name: Bobzin
- * REQUIRED* Type and Year of Model Ts owned: 2, '25 T Runabouts, '14 Touring
I will take one too !
pre15dale
- First Name: Dale
- Last Name: Kemmerer
- * REQUIRED* Type and Year of Model Ts owned: 1909 touring 1911 open runabout
I will take one also. Dale
reolds
- First Name: Gary
- Last Name: Bausch
- * REQUIRED* Type and Year of Model Ts owned: 1925 Speedster, 1923 TT w/Fabco frame conversion
I will take one also Dan. Gary Bausch
Graybeard77
- First Name: Clyde
- Last Name: Gibson
- * REQUIRED* Type and Year of Model Ts owned: 1926 Fordor Sedan, 1926 Roadster
Graybeard77
- First Name: Clyde
- Last Name: Gibson
I will take one also. Clyde Gibson
Ken Buhler
- First Name: Ken
- Last Name: Buhler
- Board Member Since: 2012
I also. Ken Buhler
Work honestly
Stay true to your word
Get the job done right
HalSched
- First Name: Hal
- Last Name: Schedler
- * REQUIRED* Type and Year of Model Ts owned: 24 Speedster, 23 RA, 25 Fordor
I'll take one also. It would be nice to get a ball-park on $$
- Last Name: Hatch
This only to find out if there is interest in making them. If there is enough interest I will see what the cost will be. I will let you know price before I make them so I will know if you want one. I will get back as soon as I know price. Thanks Dan
Bill Anziani
- First Name: Bill
- Last Name: Anziani
- * REQUIRED* Type and Year of Model Ts owned: 1924 Coupe
I would be interested as well
John bevardos
- Last Name: bevardos
- * REQUIRED* Type and Year of Model Ts owned: Roadster, Coupe, pickup truck, 2-door
me too....
Who's still makes these gaskets, I might be in the market for a solid copper one myself.
Quickm007
- First Name: Mario
- Last Name: Brossard
Also if you have taste to do a tap for petcock it will be nice too.
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
jab35
- Last Name: Bartsch
Dan I am interested if the price is under $20. jab35<at>cornell(dot)edu Thanks for making the offer, jb
Mario
A tap for the petcock thread in the crankcase or radiator lower tank is a simple 1/8" NPT (National Pipe Thread) -USA, 4-flute tap. In the US, a $3-6 common item, inexpensive.
Caution to not tap too deep at all, use care. This tap is taper thread, like modern pipe threads are, to allow a petcock to seat and seal. But Ford crankcase and old radiator petcock holes threads are just a tad different than modern, if you tap too hard, the taper threads can enlarge and the petcock might seep. Many old crankcase petcock holes have been compromised with modern taps.
- Last Name: Hatch
I do not have a price yet, but you can be sure it will not be under $20.00. Dan
Quickm007
- First Name: Mario
Thank you Dan for the advice. Really appreciated it
Super Mario Bross
1911 Touring
1914 Speedster
1911 Touring
1914 Speedster
Scott C.
- Last Name: Clements
Wouldn't that make the correct pipe tap a 1/8" x 27 NPS tap and not a NPT tap? NPT is tapered while NPS is straight threads. NPS taps are readily available.
I would be interested in a 13/32" X 16 tap also.
dmdeaton
- First Name: Danny
- Last Name: Deaton
I would be in for one
nsbrassnut
- Last Name: Lee
Hi Dan
I'd be interested in one too, if you are OK with mailing to Canada.
Jeff
Nova Scotia
Jeff
Nova Scotia
TLeroux
- First Name: Tom
- Last Name: Leroux
- Board Member Since: 2010
I will also take one
tom leroux
tom leroux
Ken Buhler
- First Name: Ken
- Last Name: Buhler
James,
We can't tell the supplier what they should sell it for. I think that if you can't afford the part, do without unless you can provide a better part for less. We need to turn this hobby from cheap to fair.
Ken Buhler
Work honestly
Philip Lawrence
- First Name: Philip
- Last Name: Lawrence
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1917 Runabout, 1919 Touring
- Board Member Since: 2014
Dan, I would be interested in one also.
- Last Name: Hatch
Working on price. Will let you know what I come up with. Thanks Dan
ewdysar
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
It doesn’t appear that James was suggesting what the price should be, but merely what he would be willing to pay. Since no indication of price had been mentioned, I think that his comment was appropriate.Ken Buhler wrote: ↑Thu Nov 21, 2019 1:10 amJames,
Ken Buhler
Keep crankin’
Eric
The petcocks are pipe thread not straight thread. Sorry for thread drift.
