Ring gear and pinion
Haroldc30
First Name: Harold
Last Name: Chambers
* REQUIRED* Type and Year of Model Ts owned: 1925 fordor. 1923 touring
Post by Haroldc30 » Wed Nov 13, 2019 10:35 am
Hello everyone. Thanking about changing my pinion gear.I've got a 11tooth pinion and a 40 tooth ring gear can I use a 10 tooth pinion on the 40 tooth ring gear. Thanks in advance Harold
TonyB
First Name: Tony
Last Name: Bowker
Re: Ring gear and pinion
Post by TonyB » Wed Nov 13, 2019 10:43 am
Yes.
I did quite successfully on the Town Car. It required a little more effort than an 11 tooth pinion but just a few shims.
Tony Bowker
La Mesa, California
Aarongriffey
First Name: Aaron
Last Name: Griffey
* REQUIRED* Type and Year of Model Ts owned: 1926 touring
Post by Aarongriffey » Fri Nov 15, 2019 1:02 am
I built a speedster with a Warford aluminum three speed and a 10 tooth pinion.
The 10 tooth was made to run against the stock ring gear.
The gout to one rear end gives you plenty of power in direct Warford or high Ruxtell.
But....if going up a slight upgrade if you run in high Ruckstell or direct Warford the motor is running very fast to tour with stock T’s.
If you run in overdrive Warford the engine will overheat from running too slow and lugging.
If you run in underdrive Warford or low Ruckstell everybody with the stock setup will overheat because their engines will be running too slow.
We found I just could not lead tours with that setup. The 3:63 overall gear ratio is by far the best in hilly country.
Post by Original Smith » Fri Nov 15, 2019 10:38 am
Unless you do a lot of driving on mountain roads, I would suggest sticking with the stock ratio.
Post by John kuehn » Fri Nov 15, 2019 10:48 am
Changing the differential gears from original has shown to be questionable after years of reading different outcomes on the forum. More than a few have noted that overall leaving the original gear ratio is the best way to go. Different opinions on this will always arise.
Joe Bell
First Name: Joe
Last Name: Bell
Post by Joe Bell » Fri Nov 15, 2019 11:16 am
If you are pulling hills all the time the ten tooth is great but if you are flat lands I would run the eleven tooth.
