Authentic Top Trim Pieces
Mark Osterman
Topic author - Posts: 1014
- Last Name: Osterman
Am thinking about rebuilding the top on my ‘23 runabout. I have these pieces that were used to finish the ends of hidem welt. The top one was near the arm rest. Thinking one in the middle is model A rather than T. The bottom one was on the top trim.
TonyB
- First Name: Tony
- Last Name: Bowker
Re: Authentic Top Trim Pieces
I have seen the style on the second picture on what I believe to be fairly original cars.
I don’t know a modern source.
Tony Bowker
La Mesa, California
La Mesa, California
- Last Name: Strange
- Board Member Since: 2013
You have a lot of priming and sanding to do on that top one, I've done it, and to me it's worth it for a non obtainable part. It would be nice for someone that does stamping to be able to remake that part. If there is someone out there that can do it, I have a NOS spear to loan.
TonyB
- First Name: Tony
- Last Name: Bowker
A friend contacted me with pictures of trim ends available from Macs. One looks very similar to the one I have previously seen on Ts.
Apparently Macs has several other styles in their catalog.
Tony Bowker
La Mesa, California
La Mesa, California
Jim, Sr.
- First Name: Jim, Sr.
- Last Name: Rodell
- * REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
These are photos of an original 1924 touring.
1922 Coupe , 1926 Touring
Thanks Jim for posting. I can always rely on you to post important information with no guessing allowed!!
Mark Osterman
Ok guys. So, it appears that I’m missing one of these. Anyone have one to spare that is as crappy as mine?
Dropacent
- Last Name: Morsher
I have just one, a couple shades better. It’ll be in the mail. T
Mark: When you get mine, you'll have an extra! Happy Thanksgiving!
- First Name: Keith
- Last Name: Townsend
So, I would like a little more edjumacashion about these end pieces...
1) Is the end for the top the pointed end and the end for the armrest square the end?
2) Is the arrow-head shaped piece (finger pointing #1) the same as the rusty ends (#4 & #5 from the left) but the notches out of the corners?
2b) Could a #1 be made from a #4 or #5?
3) Was the non-notched type used? If so, when?
I presume these would only been used with the hide 'em welt used from about 1923-1925?
Keith
Keith
Mark Osterman
Thanks Tim!
D Stroud
- First Name: David
- Last Name: Stroud
- Board Member Since: 2011
It looks to me like some of those that Tim posted could be made to look very close to an original with a bit of time and a Dremel with a cutoff wheel. Dave
1925 mostly original coupe.
The problem with converting a common style spear to the Ford style is the Ford style is bigger. Yes, you can alter a common one to have the tails like a Ford one, but it still will not be correct. The Ford spear is wider from top to bottom.
The spears posted above as far as I know were only used by Ford. They can't be made from anything. If someone with a metal stamping business would be willing to make a die to stamp these, I'm sure it would be a big seller for the purists.
