Converting a Ford to a Truckford - video
Rob
Topic author - Posts: 1588
- First Name: Rob
- Last Name: Heyen
From the National Archives: (click on the link to see the video)
https://s3.amazonaws.com/NARAprodstorag ... c-3339.mp4
ewdysar
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
Re: Converting a Ford to a Truckford - video
I wonder what the gear reduction is for the sprocket drive? And what happened to the roadster body (which looked to be in like-new condition)?
All in all, a spiffy way to build a one-ton truck...
Keep crankin’
Eric
Keep crankin’
Eric
HPetrino
- First Name: Henry
- Last Name: Petrino
Eric,
I don't know the precise reduction, but I bet a race with a stock TT, although boring, would be a photo finish.
2nighthawks
- First Name: Harold
- Last Name: Schwendeman
Just a rough guess by the quick "glimpse" of the chain & sprockets in the video, but looks like about two to one! Lots of power but half the speed, huh? Great video, and I also wondered what happened to those beautiful Model T bodies that were set aside during those truck conversions. I'm sure they didn't get wasted, but then in those days, I can't imagine that there would be too many people "in the market" for a stock "T" body in perfect condition,....???
- First Name: Dennis
- Last Name: Seth
Nice video thanks for posting.
I noticed that when the one fellow attached the sprocket to the axle he only hand tightened the nut to the sprocket but used a wrench to tighten the hub cap. When we assemble something on the T's everyone worries about torque wrench settings.
That is truly delightful!
thom
- First Name: Tommy
- Last Name: Coffey
I can't help thinking "what a shame". I'd like to have that body they took off!
PDGx
- First Name: Paul
- Last Name: Grohsmeyer
That was easy.
Looks like a mini Mack drive. Any idea what year that was ?
If my short term memory gets any shorter, I won’t even have thought about what I’m going to forget.
17 TT Holmes Wrecker
22 Mack AC Tiltbed Wkr
30 A Rdstr PU
58 Mack B-61 Semi Tractor / 85 Roger’s RGN
08 Philbilt Stepdeck Semi
30 A Rdstr PU
- Last Name: Strange
Odd that he only tightened the axle nut hand tight, I hope that after the filming they pulled the gear back off and installed it tightly!
Rob
- First Name: Rob
- Last Name: Heyen
Regarding the year, there is one brass T converted into a pickup (15 or 16) at the Robinsons plant. The other T’s look like black radiator with steel coilboxes. My guess is between 1917-19. After the TT was introduced I wonder if aftermarket truck kits were competitive?
HPetrino
- First Name: Henry
Interesting question Rob. The June 7, 1921 the price of a T chassis (no starter) was $345.00. At the same time a TT chassis was $495.00. So, did the kits cost $150.00 or more installed? Of course there would be other things to take into consideration, like speed and load capacity. Also, converting a used T would probably be pretty cheap.
Actually have found a hub cap that was on one of these TruckFords. When the hand tightened axle nut falls off in side the hub cap wrenched on tightly, this is the result:
D Stroud
- Last Name: Stroud
- Board Member Since: 2011
Very interesting. Of all of the T truck conversions, I have never heard of a Truckford conversion. I wonder if it was marketed under other names, it sure is very similar to other conversions. Dave
1925 mostly original coupe.
David
Don't know how long this co. survived, could only find ref. in magazines in 1916-1917.
April 1917
Aug 1916
April 1917
Aug 1916
