Spiral Tube Radiator.
Topic author - Posts: 6895
While looking for some KD info I stumbled across this. I had not seen it before.
- First Name: Henry
- Last Name: Petrino
Re: Spiral Tube Radiator.
Interesting item. I wonder why they marketed it as for a TT when, as we all know, if it fit a TT it would fit a regular T. Also interesting is that they marketed a "Type B" for 1917-21 trucks (obviously low radiator models) and a "Type A" for 1913-16 models. Somebody was confused.
Thanks for posting this.
- First Name: Dennis
- Last Name: Seth
I would hazard a guess that they singled out trucks in that ad because it was published in "The Commercial Motor" magazine
- First Name: Adam
- Last Name: Doleshal
I bet the aluminum tanks all corroded out in a couple years and there are none left!
- First Name: Dick
- Last Name: Fischer
- * REQUIRED* Type and Year of Model Ts owned: 1912 Touring
"All Parts Machined to Jigs and Interchangeable"
In England ? You gotta be kidding me. They should have sold the concept to Rolls Royce !
- First Name: Susanne
- Last Name: Rohner
1913-1916 are the flat sided radiators, 1917+ are the rounded-side radiators.
They remind me of something from the front of a tractor. It IS a nifty idea, tho... if the tubes had rubber o ring seals,to and the tank was also sealed to the top of the able to be removed or installed not with a soldering iron but by removing bolts to separate it from the bottom half... You take the tank off, pull the bad tubes out, put the new ones in, ake sure the rubber gasket for the tank is still good, and reattach the top tank.
