Installing modern front hub bearings
dmdeaton
Topic author - Posts: 732
- First Name: Danny
- Last Name: Deaton
What fancy tool do you all use to tighten the front bearings up with? Aside from a open end wrench sitting on the flats at a 90 degree angle. The bearings spin freely on the threads and I know how tight to make the bearings. The bearing flat ends up too deep in the hub to wrench it.
dmdeaton
- First Name: Danny
- Last Name: Deaton
Re: Installing modern front hub bearings
Forgot to mention. Late model wire wheel spindles. Looks like wood spoke hubs are easy.
Jim, Sr.
- First Name: Jim, Sr.
- Last Name: Rodell
- * REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
If you had a hubcap wrench for 1926-27, Ford made a change to fit that condition.
1922 Coupe , 1926 Touring
dmdeaton
- First Name: Danny
- Last Name: Deaton
More tools to buy
Never a bad thing, Danny!
Bud Delong
- First Name: Kenneth
- Last Name: DeLong
To me it would seem easy and cheap to weld 2 pices of flat stock on a old/worn/or off shore socket!!
Bud.
dmdeaton
- First Name: Danny
- Last Name: Deaton
Great minds think alike!bud delong wrote: ↑Tue Dec 31, 2019 8:01 pmTo me it would seem easy and cheap to weld 2 pices of flat stock on a old/worn/or off shore socket!!Bud.
