A-C accessory brakes
ewdysar
- First Name: Eric
- Last Name: D
- * REQUIRED* Type and Year of Model Ts owned: 1914 Touring, 1915 Speedster #32, 1916 Touring, 1927 Runabout
Re: A-C accessory brakes
Interesting information, Tim.
Has anyone here seen a set of A-Cs that were set up to the emergency brake as shown in picture labelled #1? And it looks like set up #3 uses 1 cable attached to the emergency brakes and another cable run to the brake pedal and center mounted equalizer pulley. The number 2 set up looks like all of the cable brake installations that I’ve seen described here on the board.
Keep cranking’
Eric
Keep cranking’
Eric
