23 model t touring head light reflectors
Rich Huggins
First Name: Rich
Last Name: Huggins
* REQUIRED* Type and Year of Model Ts owned: 1923 touring- 1922 deverley truck -1922 center door
Post by Rich Huggins » Fri Dec 27, 2019 8:09 am
Head light reflectors need to be cleaned, Rust film very little , finger prints how do i clean look,s like a delicate plating
Last Name: Humble
Board Member Since: 2006
Re: 23 model t touring head light reflectors
Post by Humblej » Fri Dec 27, 2019 8:22 am
Reflectors are silver plated. If the plating is intact, they will clean up like a mirror with silver polish.
Post by DanTreace » Fri Dec 27, 2019 9:20 am
Rubbing with silver polish, try to not rub in circles as that affects the reflective image.
Dan_Jensen
First Name: Daniel
Last Name: Jensen
Post by Dan_Jensen » Fri Dec 27, 2019 8:17 pm
If you plan on driving your car at night, the new reflectors available from the vendors with the vacuum metalized aluminum coating work very well and do not need polishing. Snyders also now sells headlight bulbs that the filaments are horizontal when installed. This makes it possible to properly focus the headlight beam.
1923 Touring low radiator
BuddyTheRoadster
First Name: Chris
Last Name: Rini
* REQUIRED* Type and Year of Model Ts owned: 1923 roadster
Post by BuddyTheRoadster » Thu Jan 02, 2020 3:03 am
An object lesson. The left reflector is an original silvered one in tolerable shape. The right reflector is one of the aluminum coated ones from Lang's. It's a world of difference, and I'll know in a few days how much difference it'll make. And of course, check that you have good grounds.
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Thu Jan 02, 2020 9:04 am
Buddy...if you’d like to sell the used one on the left, I’d be interested in it.
It matches my decent reflector and I don’t drive my car at night.
1924 Touring
