Super is ready
D.Yoder
First Name: DEAN
Last Name: YODER
* REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
Super is ready
Post by D.Yoder » Fri Jan 03, 2020 8:39 pm
A little heat helps installation.
John Warren
Last Name: Warren
Re: Super is ready
Post by John Warren » Fri Jan 03, 2020 8:43 pm
Soup is on, Yes it does give you one good shot! What's Momma say about it ? :lol:
Mark Osterman
Last Name: Osterman
Re: Super is ready
Post by Mark Osterman » Sat Jan 04, 2020 9:02 am
My soup is usually brass parts in ketchup 😄
tdump
First Name: Mack
Last Name: Cole
Re: Super is ready
Post by tdump » Sat Jan 04, 2020 9:22 am
Cook 1 part ,freeze the other,makes things fit easier.
Re: Super is ready
Post by Steve Jelf » Sat Jan 04, 2020 9:45 am
What is it?
Ruxstel24
Last Name: Hanlon
Re: Super is ready
Post by Ruxstel24 » Sat Jan 04, 2020 9:53 am
Some of the newer modern transmissions have a press-fit on internal bearing to shaft fit. A special fixture is needed for disassembly and you use heat transfer plugs for assembly.
Plugs are heated to 450F degrees, usually on a hot plate and then put inside the bearings for a few minutes and everything slides together with ease. Without doing this you can break the cases...
Last Name: Wrenn
Re: Super is ready
Post by TWrenn » Sat Jan 04, 2020 10:09 am
Steve, it's Zahnradsuppe! :lol:
First Name: Dallas
Last Name: Landers
Re: Super is ready
Post by Dallas Landers » Sat Jan 04, 2020 10:11 am
Looks like gearlosh for supper :D
Re: Super is ready
Post by Steve Jelf » Sat Jan 04, 2020 10:49 am
It's not Model T, so I was thinking maybe some other make or pre-T Ford.
old_charley
First Name: Bryan
Last Name: Ostergren
* REQUIRED* Type and Year of Model Ts owned: 1914 cut-off touring/pickup: 1922 Touring car: 1921 TT Dump Truck
Re: Super is ready
Post by old_charley » Sat Jan 04, 2020 11:24 am
Looks to be the clutch disc drum from the turbo 400 clutch disc setup in Lang's catalog
D.Yoder
First Name: DEAN
Last Name: YODER
Re: Super is ready
Post by D.Yoder » Sat Jan 04, 2020 11:57 am
Turbo 400 clutch disk.
Now cooking 26/27 tail shafts in lye water
Last Name: Hjortnaes
Re: Super is ready
Post by DHort » Sat Jan 04, 2020 12:09 pm
There is no Momma, so he can cook whatever he wants. Inside or out.
D.Yoder
First Name: DEAN
Last Name: YODER
Re: Super is ready
Post by D.Yoder » Sat Jan 04, 2020 12:15 pm
Turbo400
Turbo400
KeithG
First Name: Keith
Last Name: Gumbinger
Re: Super is ready
Post by KeithG » Sat Jan 04, 2020 12:39 pm
Dean, Could you please tell us why you use lye water instead of regular water to cook the '26 - '27 tailshafts?
Thanks,
Keith
First Name: Dallas
Last Name: Landers
Re: Super is ready
Post by Dallas Landers » Sat Jan 04, 2020 12:45 pm
For flaor of course! Thats no lye :D
First Name: Dallas
Last Name: Landers
Re: Super is ready
Post by Dallas Landers » Sat Jan 04, 2020 12:46 pm
Flavor!!!
D.Yoder
First Name: DEAN
Last Name: YODER
Re: Super is ready
Post by D.Yoder » Sat Jan 04, 2020 1:39 pm
Lye to de grease and removes rust.
Very caustic do outside !
Joe Bell
First Name: Joe
Last Name: Bell
Re: Super is ready
Post by Joe Bell » Sat Jan 04, 2020 3:15 pm
Always use eye cover, my father years ago showed me a guy with a white eye from getting lye in it, that made me remember every time!!
