Pictures needed of 24 coupe inside bottom trim pieces
Robert Lawson
Last Name: Lawson
* REQUIRED* Type and Year of Model Ts owned: 1923 Runabout, 1924 Coupe
Post by Robert Lawson » Thu Jan 09, 2020 8:27 pm
My 24 coupe didn’t have the bottom inside horizontal molding pieces of the quarter windows. I’ve tried for years to find them with no luck so would like some pictures and dimensions to try and make them. Would appreciate any help.
Robert Lawson
Last Name: Lawson
Re: Pictures needed of 24 coupe inside bottom trim pieces
Post by Robert Lawson » Thu Jan 09, 2020 11:03 pm
Ttt
24tcoupe
First Name: Laird
Last Name: Powers
* REQUIRED* Type and Year of Model Ts owned: 1924 Model T Coupe
Post by 24tcoupe » Fri Jan 10, 2020 11:54 am
Are you looking for the metal or wood pieces? Send over a picture of where this piece of trim goes. Also is it for both sides?
Agreement.pdf
(348.87 KiB) Downloaded 196 times
Robert Lawson
Last Name: Lawson
Post by Robert Lawson » Fri Jan 10, 2020 12:23 pm
The metal pieces that go on both sides that cover this area.
Post by Rich Eagle » Fri Jan 10, 2020 12:40 pm
I will look for better photos but here are these for now.
Apologies to those I stole them from.
Post by Rich Eagle » Fri Jan 10, 2020 12:52 pm
This shows them a bit better.
http://www.vintagecartruckpartsshop.com ... -1923.html
I don't see that add there but that is where the picture came from.
Robert Lawson
Last Name: Lawson
Post by Robert Lawson » Fri Jan 10, 2020 1:09 pm
Do you have any clearer pictures?
24tcoupe
First Name: Laird
Last Name: Powers
Post by 24tcoupe » Fri Jan 10, 2020 1:21 pm
So you just need the bottom metal pieces? I'll take a look and see what I have.
Post by Rich Eagle » Fri Jan 10, 2020 1:29 pm
I don't have better photos. I went out to the garage but apparently don't have any of those.
These are earlier ones '20 or so. There may be similarities.
Robert Lawson
Last Name: Lawson
Post by Robert Lawson » Fri Jan 10, 2020 3:02 pm
Thanks for the help.
Post by John kuehn » Fri Jan 10, 2020 3:33 pm
Here is a pic of the inside lower trim piece in my 24 Coupe. It has to be installed first and then the side and top pieces. You might could squeeze it in but it would scratch the paint.
You can see that it has 3 screws for attachment.
There is a post in the classifieds selling Coupe body parts. Maybe he has some interior trim pieces. These don’t show up to often. There is no reproduction interior closed car trim being made. Good luck.
Robert Lawson
Last Name: Lawson
Post by Robert Lawson » Fri Jan 10, 2020 4:21 pm
Thanks for the picture. I figured the piece had four holes because the piece it mounted to had 4 holes.
Post by Rich Eagle » Fri Jan 10, 2020 4:45 pm
The bodies did some evolving through '24 and '25. It may be that the number of screws to hold that piece was a mid year change or a difference with suppliers. The 3rd photo I posted shows 4 holes as does your car.
FWIW Ford called that piece a Strip (Quarter Garnish Finish) and listed a R. H. and a L. H. 17390X and 17391X 1924-25. I can't tell you what the difference would be.
