TT REAR AXLE AUX TRANSMISSION ID
StanHowe
Topic author - Posts: 979
- First Name: Stan
- Last Name: Howe
Anybody know what this is?? It's on a C Cab TT a guy in Billings is getting ready to sell.
Re: TT REAR AXLE AUX TRANSMISSION ID
Stan
Right its not a Lincoln brand TT accessory.
Dropacent
- Last Name: Morsher
fuller trans. TT REAR AXLE AUX TRANSMISSION ID
It’s not a lincoln, as I have one on my Tt. I believe it’s a Fuller brand, made in Kalamazoo. Not 100% sure , but an educated guess. I had one 20 years ago, and was able to remachine it a bit to make it an overdrive. I’m starting to forget more than i remember.
Right on Tim, very educated guess.
June 1925 Ford Dealer and Owner
Dropacent
That’s a beautiful ad, Dan, thanks!
StanHowe
- First Name: Stan
- Last Name: Howe
Thanks, I am always amazed at the accessories they made for Fords and the knowledge of them on this forum!!
HPetrino
- First Name: Henry
- Last Name: Petrino
Neat gizmo. Since it's for a TT, I would imagine it's a direct and over, but it doesn't say that anywhere I can find. Does anybody know for sure?
Dropacent
Yes, I know for sure they were under and direct. Very few original TT transmissions were OD. Pulling power is what was needed back then. I’m recalling now the one I had was in pretty poor shape. In my opinion, they were not built very stout compared to other brands. Surprising because the fuller company made a whole car before they shifted( pun) to the transmission line. They continued building transmissions way after the model T and A days, so they must have been reliable. Perhaps the one example I had might have had a million hard miles on it. That’s one reason I remade it as an overdrive unit. It was a challenge but worthwhile.
Dropacent
If you read the advert., you just cut the torque tube, the original driveshaft passes right through the unit. Also, no neutral, another good feature.
StanHowe
- First Name: Stan
- Last Name: Howe
Fuller made a ten speed for big trucks. A lot of them ended up in International Diesels. At one point 60 years ago I was working for Northern Tank Lines hauling crude oil out of the Medora, North Dakota oil production treater sites. Several of the old worn out Kenworths had ten speed Fullers in them along with a two speed Eaton rear end or a Brownie aux trans. You could get out and walk around it and check your tires coming up the hills.
