Roof 16 engine help
Alex Dragone
First Name: Alex
Last Name: Dragone
* REQUIRED* Type and Year of Model Ts owned: 1910 Roadster, 1911 Torpedo, 1915 Touring, 1926 Roadster
Roof 16 engine help
Post by Alex Dragone » Sun Jan 26, 2020 11:11 am
I am finally putting my 16 Valve Roof engine together and want to have a few words of advice from others. It is a model B roof and I am using a new scat crank. It has been suggested to me that for driving a stipe 250 cam and stock flattop pistons are the best way to go. What do others think who have had experience with these heads? I want power but I don’t want big problems either. The 250 cam and stock pistons have been suggested to me by a trusted expert.
So I need to know the following:
1: what do I do for a head gasket?
2: what do I do for valve springs?
3: is a stipe 250 going the best choice for a cam or should I go with a higher lift? Like a 280 or 290?
Any help is appreciated. Thanks!
Joe Bell
First Name: Joe
Last Name: Bell
Re: Roof 16 engine help
Post by Joe Bell » Sun Jan 26, 2020 11:40 am
The std. grind cam is plenty, that head perform really well as stock, if you can find a big bore carb to help make it breath would be great.
Joe Bell
First Name: Joe
Last Name: Bell
Alex Dragone
First Name: Alex
Last Name: Dragone
Post by Alex Dragone » Sun Jan 26, 2020 11:44 am
Joe, thanks very much for the reply. Yes I am using a nice Miller master carb and has the same size large throat as the original Roof intake.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Sun Jan 26, 2020 10:03 pm
It will run a heck of a lot better if you increase the compression ratio. Take the time to CC the head - I think you will find the CR to be under 5:1 with stock pistons.
