Steering shaft?
D.Yoder
First Name: DEAN
Last Name: YODER
* REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
Steering shaft?
Post by D.Yoder » Mon Jan 27, 2020 7:36 pm
What is the correct angle for the bottom of the sterling shaft?
Adam
First Name: Adam
Last Name: Doleshal
Re: Steering shaft?
Post by Adam » Mon Jan 27, 2020 7:47 pm
Try a rear hub on it. Maybe the same taper. Rear hub / axle shaft is 1+1/2” to 1’.
got10carz
Last Name: Meixner
* REQUIRED* Type and Year of Model Ts owned: 1911,13,14,19,23,25,26,27
Re: Steering shaft?
Post by got10carz » Mon Jan 27, 2020 8:35 pm
Alot of tapers are 3 and1/2 degrees on each side. 7 total, although I've never checked a steering shaft. It would need to be in a lathe and indicated in.
