Steering shaft?
D.Yoder
Topic author - Posts: 263
- First Name: DEAN
- Last Name: YODER
- * REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
Steering shaft?
What is the correct angle for the bottom of the sterling shaft?
Adam
- First Name: Adam
- Last Name: Doleshal
Re: Steering shaft?
Try a rear hub on it. Maybe the same taper. Rear hub / axle shaft is 1+1/2” to 1’.
got10carz
- Last Name: Meixner
Re: Steering shaft?
Alot of tapers are 3 and1/2 degrees on each side. 7 total, although I've never checked a steering shaft. It would need to be in a lathe and indicated in.
