need info on plate under radiator that anchors tension rods, size and shape.
this is for 1926 mailman special
send private message for photos
snowbird parts info
RodellJunior
- Last Name: Rodell
Re: snowbird parts info
William,
Here is a drawing showing the parts of the Snowbird. The plate you are referring to is trapezoidal and replaces the bar under the front spring clamp. It should be easy to have one laser cut from 1/2" steel. I would love to see pictures of your Model T snow machine.
Jim
Jim
Jim, Sr.
- First Name: Jim, Sr.
- Last Name: Rodell
- * REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
If you "click" on the drawing it will enlarge. Do it twice to enlarge twice.
1922 Coupe , 1926 Touring
Oakknoll
Topic author - Posts: 7
- First Name: William
- Last Name: Crogan
- * REQUIRED* Type and Year of Model Ts owned: 25 TT, 25 touring, 27 pickup,13 runabout
would like to see just what this front plate looks like for a better copy, any idea where there might be one to look at?
Hodag88
- Last Name: Bruso
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster
I sent you an email regarding this part....
