External Oil Pump Plumbing
Topic author - Posts: 1504
- First Name: Terry
- Last Name: Woods
For those running an external oil pump, driven either at the generator location, or belt or cam driven, how and where does your line from the pump enter the block? Through the side of the block casting, or through the side of the thinner crankcase pan?
- First Name: Les
- Last Name: Schubert
Re: External Oil Pump Plumbing
Through the side of the pan and located in the area of the centre main
- First Name: Kevin
- Last Name: Pharis
- First Name: Walt
- Last Name: Berdan
- * REQUIRED* Type and Year of Model Ts owned: '18 Speedster had 25 touring and 26 coupe
Also through the side of the pan near the center main.
