1926 Dash board screws
Mopar_man
Last Name: Govoni
Post by Mopar_man » Thu Feb 06, 2020 10:19 pm
Is the dash on a 26 Touring held on with flat head bolts and washers that the head of the bolt fits into? Same to hold the steering column?
Howard Tomlinson
First Name: Howard
Last Name: Tomlinson
Re: 1926 Dash board screws
Post by Howard Tomlinson » Thu Feb 06, 2020 10:54 pm
Nickel plated oval head machine screws. Lang's sells them under "interior screw set". I can't find them locally.
Last Name: Patrick
Post by jiminbartow » Fri Feb 07, 2020 12:14 am
We have an old style hardware store here in central Florida called Crowder Brothers that has them. Some Ace Hardware stores have them too, in separate steel boxes in the fastener aisle. Jim Patrick
George N Lake Ozark
First Name: George P
Last Name: Clipner
Post by George N Lake Ozark » Fri Feb 07, 2020 12:39 am
And held in place by square nuts on the backside
Post by Allan » Fri Feb 07, 2020 4:41 am
On our Canadian products I believe there are no cup washers. The panel itself has a raised lip around the holes, and the screws sit in this lip.And, they are Robertson screws wuth the square hole drive.
Allan from down under
Gonenorth
First Name: Kevin
Last Name: Whelihan
Board Member Since: 2008
Post by Gonenorth » Fri Feb 07, 2020 9:23 am
You can get the screws at McMaster-Carr, Seems to me they are 1/4-20 oval head. Forget the length at the moment. Not real expensive.
Post by Original Smith » Fri Feb 07, 2020 10:32 am
I personally like stainless steel.
