I pulled the tank for cleaning tomorrow.
Tar & beans
Topic author - Posts: 263
- First Name: DEAN
- Last Name: YODER
- * REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
Tar & beans
I do not think it will run on TaR & beans
- Last Name: Hjortnaes
Re: Tar & beans
Needs to be beans and molasses. Throw in some sugar, too.
- Last Name: Jarzabek
- Board Member Since: 2008
TarBeans
" Tarbeans " is the nickname of a a small community college athletic program in Alabama ...
I would imagine ....
FJ
FJ
Google “ Model T Transport “
MTFCA - MTFCI - MAFCA Member
- First Name: DEAN
- Last Name: YODER
Re: Tar & beans
Cleaning started
- First Name: Stan
- Last Name: Howe
Re: Tar & beans
Plug the openings, put some gravel from the driveway in with some water, lacquer thinner, soap and a handful of rusty old square nuts of various sizes, bungee cord it to the back wheel on your 8N and go for a slow drive for an hour or so. It will knock all the crap loose, the inside will be shiny and at least hopefully be clean enough you can solder it with a torch without worrying about it blowing up. If you are, run the hose from the wife's vacuum cleaner from the exhaust pipe on the 8N to the inside the tank, let it run for awhile before and while you are soldering. She will never know and you won't blow the tank up. =)
- Last Name: Rutt
- * REQUIRED* Type and Year of Model Ts owned: 1926 fordor
Re: Tar & beans
Here is how I cleaned my tank.. cut the bottom out, cleaned it an welded it back on..[image][/image]
- First Name: Jack
- Last Name: Putnam
Re: Tar & beans
Stan has it. It works every time. A shop vac will remove all the stones when done.
Re: Tar & beans
Stan/Jack, will it work with a Jubilee, too, or is that too new?
- First Name: Stan
- Last Name: Howe
Re: Tar & beans
Too new. Dean has an 8N.
- Last Name: Osterman
Re: Tar & beans
I plugged both holes with dish detergent solution and a few pounds of bbs. Then rolled it around on the lawn. Flushed it out and removed the bbs followed by an alcohol wash and evaporation dry. Beautiful on the inside. I make sure there is always at least half full with non ethanol gas.
