Non-Tarnishing Coolant
Topic author - Posts: 182
- First Name: Bob
- Last Name: Coiro
- Board Member Since: 2009
The neck of my radiator drips anti-freeze and this tarnishes the heck out of my brass radiator. Of course, I need to get that fixed, but in the meanwhile, is there a coolant (besides distilled water) that does not tarnish brass?
- Last Name: Jorgensen
- Board Member Since: 2013
Re: Non-Tarnishing Coolant
I use distilled water with an anti-corrosion additive, I think I used "Water Wetter". I also heard water soluble oil (cutting oil) added to distilled water will retard corrosion. Of course, neither of these is antifreeze, so one must either drain in winter, or store at well above freezing temperatures.
Wayne Jorgensen, Batavia, IL
1918 Runabout
1918 Runabout
- First Name: Erik
- Last Name: Johnson
If you don't have cutting oil, you can use water pump lubricant aka "anti-rust" which is also water soluble oil.
The drawback is that it can effect rubber hoses over time.
Water pump lubricant is getting harder to find these days at the auto parts store but NAPA does carry it:
https://www.napaonline.com/en/p/ZRXZXC0 ... +lubricant
Other brands of water pump lubricant that your local auto parts store might carry are Gunk, Bardahl, or Motor Medic.
