TT ring gear
Topic author - Posts: 88
- First Name: Rod
- Last Name: Petrie
- * REQUIRED* Type and Year of Model Ts owned: 1926 TT
TT ring gear
Can someone tell me where I can get a ring gear made for my 26TT? It is a 31 tooth gear and worn out.
Re: TT ring gear
This post is from 2016, read the whole thing. Donnie Brown posted about price increase even back then;
http://www.mtfca.com/discus/messages/59 ... 1477417371
Another avenue if you can't find a good TT ring gear. The Model AA worm drive ring gear mounts the same but from what I have read, is wider at the teeth but can be fitted with some re-work.
Googling "mtfca; TT ring gear" you can find some information on what is considered worn, for example;
http://www.mtfca.com/discus/messages/50 ... 1424348101
Chances are if the ring gear is severely worn, so will be the worm.
