I am getting things ready for an upcoming swap meet (March 15th at Russ Milne Ford, 24777 Hall Road, Macomb, MI in case anyone is interested) and need some help to ID the application of a Ford part. Hopefully someone here has a Ford Parts list/book that goes up to 1955, all the ones I have stop at 1947 or 1948. The part in question is FDA-14677-A it is a power window/seat relay. It is a 6v relay so that would make it 1955 and earlier, I just need to know what years and models it would fit (I like to have everything labeled well). I would assume it would be Lincoln and maybe Mercury, any information you can offer would be appreciated.
FDA-14677-A
Power Window/Seat Relay
Years ?
Make/Model ?
Need help to ID a Ford, non-Model T part.
Pep C Strebeck
Topic author - Posts: 646
- First Name: Joseph
- Last Name: M
DLodge
- First Name: Dick
- Last Name: Lodge
Re: Need help to ID a Ford, non-Model T part.
Remember that Google is often your friend.
https://www.fordbarn.com/forum/showthre ... &showall=1
https://www.ebay.com/itm/1955-lincoln-f ... SwUuNctf8s
https://www.ebay.ie/itm/1955-lincoln-fo ... 3454078314
Just follow where it leads....
Pep C Strebeck
- Last Name: M
Yes, I saw all of that. None of it gives any make, model or year other than a 1955 Lincoln and "may fit others". Just hoping someone here has the Ford Chassis and Parts book that would cover through 1955. I would think that a relay of this size would fit others models and years, it is as big as a starter solenoid.DLodge wrote: ↑Thu Feb 13, 2020 1:43 pmRemember that Google is often your friend.
Just follow where it leads....![]()
You might try asking on Fordbarn.com in the late V8 forum.
Jim, Sr.
- First Name: Jim, Sr.
- Last Name: Rodell
- * REQUIRED* Type and Year of Model Ts owned: 1922 coupe, 1926 touring
I found it listed in my 1949-54 Ford Passenger parts catalog.
FDA-14677-A is Relay assembly (window regulator safety)
For all 1954 Ford passenger cars except Sedan Delivery and Station Wagon
Only 1 required per vehicle
This must be a safety device in the circuit because the window regulator relay for the same vehicle is FAA-14512-A, and 4 are required.
1922 Coupe , 1926 Touring
Pep C Strebeck
- Last Name: M
Jim, Sr. wrote: ↑Sat Feb 15, 2020 1:32 pmI found it listed in my 1949-54 Ford Passenger parts catalog.
Jim,
Thank you very much. The information is very much appreciated.
