Mystery Front Axle Bits
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Sat Feb 08, 2020 11:21 am
I’m working hard to save every last little usable bits off of my ‘25 parts chassis before I haul the rest to the metal recycler and came across these little clamps.
I thought at first that they might be towing hooks, but they’re facing the wrong way. Could they be part of an aftermarket gizmo of some sort? If so, and someone is needing them, I’d like to find a new home for them.
They look too purposeful and fit too precisely to make me think they’re homemade.
1924 Touring
Re: Mystery Front Axle Bits
Post by Rich Eagle » Sat Feb 08, 2020 11:43 am
I think they are for a strap type of shock absorber.
Dan McEachern
First Name: DAN
Last Name: MCEACHERN
Post by Dan McEachern » Sat Feb 08, 2020 12:08 pm
Rich is correct- those clamps are for the webbed strap from a snubber to attach to the front axle. I believe Ford offered a snubber as an accessory on the improved Fords of 26-27. A common brand name was Gabriel. The snubber unit attached to the side rail of the frame near the front cross member and the strap from the snubber unit extended vertically down to the clamp on the front axle.
dobro1956
First Name: Donnie
Last Name: Brown
Post by dobro1956 » Sat Feb 08, 2020 12:15 pm
They are correct. They are snubber strap brackets. Someone needs them. That is the part that is usually missing.
Post by Rich Eagle » Sat Feb 08, 2020 12:50 pm
Similar to these:
JSteele
First Name: John P.
Last Name: Steele
* REQUIRED* Type and Year of Model Ts owned: 1915 Roadster
Post by JSteele » Sat Feb 08, 2020 7:02 pm
Hi Don, sent you an email. I would love to purchase those. I have NOS shocks but not the axle mounting hardware.
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Sat Feb 08, 2020 10:45 pm
Hi John
Haven’t seen your email yet. If you text...text me at two81-seven87-8418.
No need to purchase them...I’ll just send them to you.
1924 Touring
Altair
First Name: David
Last Name: Menzies
Board Member Since: 2012
Post by Altair » Sun Feb 09, 2020 2:34 am
My grandson has those snubber straps on his Ford Ranger to control the suspension in rough terrain, they are aftermarket but still used today.
ABoer
First Name: Anthonie
Last Name: Boer
* REQUIRED* Type and Year of Model Ts owned: 1912 touring 1923 roadster 1925 pickup
Post by ABoer » Mon Feb 10, 2020 5:07 am
Don A.
I have one [Snubbers] ,but I think there some parts missing .
Toon
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Sat Feb 15, 2020 8:48 pm
John...I removed the “gizmos” and started cleaning them up.
One of them looks almost new after some time with the wire wheel. The other one fought me more coming off and I broke the bolt. So you’ll have to find another square headed shoulder bolt to match.
I’m gonna try to extract the broken bolt and finish cleaning up the second one.
1924 Touring
