Unique Switch Plate - where used?
Topic author - Posts: 6559
I came across this the other day. Looks like a '26 and appears to have a rectifier on the back where the ammeter would be. Would appreciate some info on it. Thanks
- Attachments
- IMG_0853.JPG (55.71 KiB) Viewed 3864 times
- Last Name: Tannehill
- Board Member Since: 2002
Re: Unique Switch Plate - where used?
Looks like a TT SWITCH for 26/7 non generator maybe even starter. There were model T cars that came out with all the fancy stuff too. Who needs a stinking generator, who needs a starter & who needs 21 inch wheels.
D.Yoder
- First Name: DEAN
- Last Name: YODER
- * REQUIRED* Type and Year of Model Ts owned: 19tour,24tour,25rdpu,27rd.26coupe,TT's,& tractor conversions
Non starter car with Magnito lights, the transformer—inductor is the dimmer.
AndreFordT
- First Name: Andre
- Last Name: Valkenaers
1926 non starter Roadster and touring.
With this swicht go no demoutable wheels, petrol side lights and a Model O tail light.
The starter holes and the generator hole are covered with strait metal plates.
Behind the place where the Amp. meter should be, there is a coil resistant to make the difference between high and low front light with the magneto current.
I just have a photo of the tail and side lights. They came with my 1926 touring ( engine number is late 1925).
Just my opinion.
Andre
Belgium
Just my opinion.
Andre
Belgium
- Attachments
- mijn 1926 0101.JPG (35.18 KiB) Viewed 3825 times
- DSCN060701.jpg (99.01 KiB) Viewed 3825 times
- DSCN060301.jpg (99.37 KiB) Viewed 3825 times
- DSCN060001.jpg (96.35 KiB) Viewed 3825 times
- DSCN059301.jpg (88.75 KiB) Viewed 3825 times
Are 26-27 magneto lights as miserable as magneto lights from the teens? I can't imagine having to dim mag lights.
AndreFordT
- First Name: Andre
I don't know Steve,
The 1926 touring I found had no starter or generator but I never try to run the car with only the magneto. In the wiring was no wire for the generator and the switch was missing.
As I rebuild the car, I did it with the starter and generator and set a total new wiring in the car.
Andre
Belgium
Andre
Belgium
I once knew a guy with a '26 roadster with that exact setup.
