Speedster look alikes
Dennis_Brown
Topic author - Posts: 269
- First Name: Dennis
- Last Name: Brown
- * REQUIRED* Type and Year of Model Ts owned: 1926 Roadster pickup
Is anyone running a T that looks like a speedster but using a stock engine , no auxiliary transmissions and a standard or Ruxtel rear end. Something for fun and unconcerned with speed.
Re: Speedster look alikes
That is my intent. More for fun than go. Engine will not be stock externally - making it look more "speedy" - but using period correct items. Using a plan I found on the internet as a guide. Got a ways to goDennis_Brown wrote: ↑Tue Feb 18, 2020 9:33 pmIs anyone running a T that looks like a speedster but using a stock engine , no auxiliary transmissions and a standard or Ruxtel rear end. Something for fun and unconcerned with speed.
rosenkranswa
- Last Name: Rosenkrans
- * REQUIRED* Type and Year of Model Ts owned: 1926 Touriing
I'm currently working on one that is rock standard underneath, with a minimalist body. Using stock 1926 engine, 1917 fenders, early box hood, etc. I did install RM brakes as it will be for my daughter. She's not interested in speed either, more an accessory I think for her vintage outfits. We went to the T Centennial in 2008 where she saw quite a few young ladies bombing around in speedsters - she's wanted her own ever since...
- First Name: Henry
- Last Name: Lee
Folks when building a body the key is that it fits you and possibly the next person in line. Seen a lot of period correct bodies in my day and built many for others. They may look cool, but there is nothing worst than driving a car that is uncomfortable. Ergonomics is the key! Comfort with control. You can build a period correct body with tweaks here and there, but we are not the stature these people were 90 plus years ago.
Just trying to help,
Hank
Hank
kelly mt
- Last Name: Kelly
My speedster has a T motor and a Ruckstell. The hot rod parts are a low head, distributor and a Simmons carb. It's very comfortable for long drives and moves right along.
Hank, Point well taken. Lets face it people were much smaller in stature back then and "we" need a bit more elbow room. So I'm intending to have off-set seats, passenger slightly behind drive as in a PACO. I have purchased seats, retro Mini-Cooper, because of my target body width (it also has guide rails to slide forward or backward a bit and extra thigh support). I made a mock-up using foam board using the blueprint of the plans I found on the internet (previous photos). The next step is to determine the drivers seat position (combination for steering wheel, pedal reach and seat tilt). Then the passenger position to fit within desired car body contours. The to redo all the foam board shapes and positions before cutting wood. and then.......
- Attachments
- s-l225.jpg (11.02 KiB) Viewed 4802 times
spadpilot
- Last Name: Carnahan
- * REQUIRED* Type and Year of Model Ts owned: 1917 Speedster
In line with Hank and Frank's comments on ergonomics, I'm building a modified Currier speedster....I am 6'2" - 275lbs and MaryAnn is a slender 5'11", so as you can see, there is a fit issue. The Currier Speedster has a very long hood and that requires lowering the steering column significantly, otherwise the steering wheel will be over your head. Things became even more complicated with the addition of a Vega steering box. At this point I threw up my hands and appealed to Hank Lee for ideas.....he had a solution within minutes. Please see the attached photos. Hank also brought up the idea of ergonomics and suggested tilting the seat back and installing tracks for adjusting the seat position. These tracks came out of a Ford F-150 and were modified the fit the width on my seat. The seat is hinged at the front to allow access to a custom tool box. The last order of business was the modification of a Spencer Fat Man steering wheel as once it was installed the bottom of the rim touched the seat cushion. Hank cut down the spider and had a 14" rim built to replace the 17" rim....et viola! I fit. Also, note the carriage steps...these were attached to a modified running board bracket and use the same frame holes for mounting.
Give me a shout if you have any questions, suggestions or need clarifications.
Apparently I can only attach 5 pictures to a message.....will make a 2nd posting with more photos.
Best
Dave Carnah
Best
Dave Carnah
...some people are like Slinkies....they're generally useless but fun to watch when you push them down the stairs.
spadpilot
Further photos:
spadpilot
....and a few more
spadpilot
...and apologies for the sideways pictures.
-dc
-dc
