TT Truck Part Identification
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Thu Feb 20, 2020 10:03 am
Okay you TT Truck guys. Need some help identifying this part. Any help would be appreciated. It appears to be a bushing or collar. The OD is approximately 1 1/4". The ID is approximately 1".
HPetrino
First Name: Henry
Last Name: Petrino
Re: TT Truck Part Identification
Post by HPetrino » Thu Feb 20, 2020 10:28 am
I'm not 100% on this, but I think it's a rear spring perch bushing.
richc
First Name: Rich
Last Name: Chillingworth
* REQUIRED* Type and Year of Model Ts owned: 1924 C-Cab TT
Post by richc » Thu Feb 20, 2020 10:29 am
Mark, your piece is from an early TT rear spring perch. Those early perches had a narrow casting with a collar on each end to make up the width. Later, the perch castings were full length and didn't have the collars anymore. This picture is not the best, but it shows where your collar sits.
TT Haul Cropped.jpg (31.03 KiB) Viewed 3989 times
Rich C.
civinwt
First Name: Bruce
Last Name: Hopkins
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 20TT 1Ton, 27 Runabout
Post by civinwt » Thu Feb 20, 2020 10:31 am
spacer for rear spring shackle that goes on housing perch
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Thu Feb 20, 2020 10:34 am
No. I don't think so. The spring perch bushing measures 1.00" OD and .700 ID. Thanks for the input though. :)
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Thu Feb 20, 2020 10:36 am
I think you are correct Rich! The TT spring perch bushings I have (later) fit the inside diameter of the part pictured (collar).
Mark Chaffin
Last Name: Chaffin
Post by Mark Chaffin » Thu Feb 20, 2020 10:37 am
So, would this part be considered an "early TT rear spring perch collar"?
Dropacent
Last Name: Morsher
Post by Dropacent » Thu Feb 20, 2020 11:30 am
Learn something new everyday ! I have a bunch of these, and always just used them to make split flexible collar clamps for magneto drives. They are perfect for that.
Dropacent
Last Name: Morsher
Post by Dropacent » Thu Feb 20, 2020 11:34 am
HPetrino
First Name: Henry
Last Name: Petrino
Post by HPetrino » Thu Feb 20, 2020 2:26 pm
My '18 TT is parked at my sons place 45 miles away, so I can't go look at it right now. However, as soon as Rick correctly identified it I remembered them on my truck. I remembered at the time when I had it apart (nearly 20 years ago) wondering why Ford didn't just make the casting a little bigger, which apparently was done later.
