The Future meets the Past
fbergski
First Name: Philip
Last Name: Berg
* REQUIRED* Type and Year of Model Ts owned: 1911 Touring 1916 Coupelet
Post by fbergski » Thu Feb 20, 2020 8:25 pm
I'm stuck in two times, the past and the future. While I own two model t's I work in Aerospace making high tech components. So naturally I like to apply my knowledge to the past. Last year we bought a 3D plastic printer at work to try out, at first I was skeptical that we could find a use for it. After a couple of months is came apparent it was quite handy to design a fixture in 3D then print it out in plastic for fitting purposes. Now we have three of them and they run all day long making disposable fixtures and tooling affordably.
So with that I bought a 3D printer for home use, The attached pictures shows the printer and a tool I printed out to push the piston rings into the cylinder bore evenly. I plan to make more tools and plastic bits for the car. There are many types of plastics to chose from, no structural parts for now.
1410
1411
Kuhner
First Name: Greg
Last Name: Kuhnash
* REQUIRED* Type and Year of Model Ts owned: 1917, 1921 touring 1927 RPU
Board Member Since: 2006
Re: The Future meets the Past
Post by Kuhner » Thu Feb 20, 2020 10:18 pm
What brand and model printer ?
“I don’t like nice people. I like tough, honest people”. - Woody Hayes
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Thu Feb 20, 2020 11:31 pm
Very very neat. Good for you.
1924 Touring
fbergski
First Name: Philip
Last Name: Berg
Post by fbergski » Fri Feb 21, 2020 12:31 am
Creality Ender 3D Pro
Gene_French
First Name: Gene
Last Name: French
Board Member Since: 2014
Post by Gene_French » Fri Feb 21, 2020 7:45 pm
Philip:
I have thought of using a 3d printer to produce foundry patterns … with proper software the image could be mirrored and shrinkage added to the printed pattern … just a thought … glad I am retired from manufacturing … way too complex ( or simple ) for me sometimes … always an optimist ...Gene French
First Name: Keith
Last Name: Townsend
Post by KWTownsend » Fri Feb 21, 2020 8:07 pm
Philip-
This is so cool.
I wonder what Model T could be reproduced using a 3-D printer?
Maybe the hard rubber ignition switch? Terminal block? Combination horn button/headlight switch?
fbergski
First Name: Philip
Last Name: Berg
Post by fbergski » Fri Feb 21, 2020 8:31 pm
I already made a prototype front switch plate for my Heinze coil box. I need to get the correct material for the production version.
