Valve stems for 1921.
Topic author - Posts: 397
- First Name: Chris
- Last Name: Haynes
- * REQUIRED* Type and Year of Model Ts owned: 1921 Runabout
What brand and number Valve Stems were used in 1921?
Re: Valve stems for 1921.
Ford used Shrader #777, but other sizes will work and are easier to find.
http://dauntlessgeezer.com/DG110.html
- First Name: Chris
- Last Name: Haynes
Thank you for the information.
The other commonly found one is 1/4" different length, Shraeder no 888. Most others are larger in diameter.
