Front floor board
Touring
Topic author - Posts: 9
- First Name: Jim
- Last Name: Poindexter
- * REQUIRED* Type and Year of Model Ts owned: 1924 Ford Touring
Front floor board
What is the easiest way to make your own front floor board.. 1924 Ford Touring. Thanks for the help
Re: Front floor board
Borrow one and copy it.
sportbingo
- First Name: Art
- Last Name: Taylor
I first made a template out of cardboard. I shaped the cardboard using a band saw and drill hole. After, creating a pattern I used it to make my wood floor.
If you need more information contact me.
Art Taylor
Art Taylor
Touring
- First Name: Jim
Thanks for the imformation, my problem is my motor is in another state being rebuild. It won't be back till end of the year. I am trying to have the car finished when it get back. That why I can't make a pattern. I thought there might be a blue print out their. This is my first t project.
Touring
- First Name: Jim
- Last Name: Strange
http://www.mtfca.com/discus/messages/70 ... 1491253670
http://www.mtfca.com/discus/messages/80 ... 1257864007
http://www.mtfca.com/discus/messages/29 ... 1170296383
http://www.mtfca.com/discus/messages/25 ... 1353988848
jab35
- Last Name: Bartsch
Jim: Here is a print of the bottom board, the one in front of the seat, from the Funprojects website. I suspect this one is the 'easiest' one to make. best, jb
http://www.funprojects.com/pdf/T1404B.pdf
tdump
- First Name: Mack
- Last Name: Cole
Art,where were you a couple years ago with that "tip'?
I scratched my head bare trying to figure it out and finally just decided 1 day to lay some boards together,make it way to wide and trim it down.
sportbingo
- First Name: Art
- Last Name: Taylor
My son and I glued the board together and trim the board using the pattern. Good luck Jim.
Art
Art
Dan B
- Last Name: Blaydon
The best way is to buy them from Jon Anderson. They are exact to the factory specs and fit perfect.
George Hand
- Last Name: Hand
- * REQUIRED* Type and Year of Model Ts owned: 1912 open express, 1920 touring, 1926 tudor-lisenced and insured, 1921tt project 1922 fendered chassis, 192x tt dootle bug 192xengine w/winch projects
Jim, I would like to ask did you not have a floor boards when you acquired your car?
Something I have seen is a pre 1925 T that has had a 1926-7 pedals, transmission cover or even a complete engine assembly. The pre 1925 pedals can be bothersome because they are narrow. I am saying this because the pedal spacing on the 1926-7 is different and requires a custom floor board.
Getting them from Jon is the best idea. If not, find originals to copy, and be sure to rabbet the front and back sides. They were never varnished.
Mark Nunn
- Last Name: Nunn
Don't expect dimensional lumber to fit. For my '26 Runabout I had to plane the boards to 9/16" to fit into the body's flanges and under the front board hold-down. The white panel in the photo is a piece of 1/4" hardboard that I used as a template for the upper board.
Charlie B in N.J.
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
Here's mine made from Poplar. So close they'd only fit this car. Your problem is no eng/trans in place. I'd definitely wait for it to be back in place. Anything else would be a crap shoot.
