Coil capacitors
adenautomotive
First Name: mark
Last Name: aden
Coil capacitors
Post by adenautomotive » Mon Mar 09, 2020 12:33 pm
Just got off the phone with Langs coil capacitors are on back order dont know when they will have more , anyone have a source for them i'm ready to do some coils
FATMAN
First Name: ROBERT
Last Name: BERGSTADT
Re: Coil capacitors
Post by FATMAN » Mon Mar 09, 2020 2:45 pm
I have a few, Bob
Last Name: Hjortnaes
Re: Coil capacitors
Post by DHort » Mon Mar 09, 2020 3:41 pm
Adams Antique Auto has them.
adenautomotive
First Name: mark
Last Name: aden
Re: Coil capacitors
Post by adenautomotive » Mon Mar 09, 2020 3:42 pm
Bob sent you a pm
John Dow
Last Name: Dow
Re: Coil capacitors
Post by John Dow » Mon Mar 09, 2020 9:32 pm
I have 8ea capacitors purchased from Langs last summer and never opened the package. I'd sell all 8 for $15 + shipping. PM me if interested.
Duey_C
First Name: Duane
Last Name: Cooley
Re: Coil capacitors
Post by Duey_C » Wed Mar 11, 2020 1:06 am
Dare I ask this? Do you fellows have FULL particulars on these capacitors, including micro farad ratings? I thought sadly lacking in the T world where I looked. I should've just contacted Bob! :)
I admit my focus is for OT reasons at this time. Wait, the DU-4 and ZR-4 magnetos are oft-times associated with the model T and this is a similar study/need for capacitors in rotating coil/condenser magnetos.
John E. Guitar
Last Name: Guitar
Board Member Since: 2012
Re: Coil capacitors
Post by John E. Guitar » Wed Mar 11, 2020 4:50 am
Duey C, this thread from 2011 has a lot of useful information about coil capacitors:
http://www.mtfca.com/discus/messages/17 ... 1322781074
I had the Bosch ZE1 in my Le Zebre rebuilt a year or so back by the local magneto guru. The capacitor in that was a lot smaller than the Model T capacitors.
troutjohn
Last Name: Trout
* REQUIRED* Type and Year of Model Ts owned: 1923 runabout, 1913 touring
Re: Coil capacitors
Post by troutjohn » Wed Mar 11, 2020 9:08 am
John Dow, sent you a PM.
JohnH
Last Name: Hunter
Board Member Since: 2002
Re: Coil capacitors
Post by JohnH » Wed Mar 11, 2020 8:13 pm
The capacitors are 0.47uF 400V, and most importantly have a high dv/dt rating. This is where most folk get unstuck when using ordinary types which fail quickly. http://www.funprojects.com/products/5007CAP-HiD.aspx
Duey_C
First Name: Duane
Last Name: Cooley
Re: Coil capacitors
Post by Duey_C » Thu Mar 12, 2020 1:31 am
Thank you gentlemen. Gives me info to consider. :)
Looking for 0.22 MFD 400 volt. Darn it. Thought I had dV/dT ratings in hand.
Robust enough for the ZR-4 and possibly the same capacitor for the DU-4. Working with the U-4's.
I need to contact the info-man whether it's Millifarad or Microfarad...
I let Andy do my hot T coils...
Please excuse the thread drift Mark! Did you find/get your capacitors. :)
JohnH
Last Name: Hunter
Re: Coil capacitors
Post by JohnH » Thu Mar 12, 2020 4:23 am
You can use two of the 0.47uF capacitors in series to get that capacitance, provided there's room to fit them of course.
Chris Barker
First Name: Chris
Last Name: Barker
Re: Coil capacitors
Post by Chris Barker » Fri Mar 13, 2020 4:27 am
Shouldn't that be in parallel??
Luke
First Name: Luke
Last Name: P
Re: Coil capacitors
Post by Luke » Fri Mar 13, 2020 6:27 am
No, John's correct.
2 x 0.47uF 400V caps in series will give a total capacitance of 0.235uF at 800V, certainly near enough to the 0.22uF required.
Chris Barker
First Name: Chris
Last Name: Barker
Re: Coil capacitors
Post by Chris Barker » Fri Mar 13, 2020 11:50 am
Sorry, I misunderstood.
I thought he was trying to get 0.47 from two 0.22s!
NealW
First Name: Neal
Last Name: Willford
Re: Coil capacitors
Post by NealW » Fri Mar 13, 2020 1:05 pm
A couple of months ago I tried buying some capacitors to rebuild my spare coils. Lang's was out of stock then, with no idea when they'd get more. I called Snyders and I think that they said that they had "hundreds". They are the orange, rounder ones shown in the left on the photo. They are a little wider than the one on the right that Lang's had in stock. Anyway, at least you can get those kind if other places are also out of stock on the narrower kind.
jab35
Last Name: Bartsch
Re: Coil capacitors
Post by jab35 » Sat Mar 14, 2020 9:53 am
From an earlier post by John Regan, in reference to the two capacitors shown in NealW's post:
By John F. Regan on Tuesday, February 26, 2013 - 02:09 pm:
",,,,the capacitor that Snyder has pictured on his web site is the SBE type 418 cap and it is commonly called an "orange drop" capacitor and it is the same capacitor that Fun Projects sells as our part number 5007CAP and is the cap with the 900 dV/dT rating. The capacitor pictured above and marked 011-408474 is the capacitor Fun Projects sells as 5007CAP-HiD which is rated at 1700 dV/dT and is a bit smaller than the "orange drop" type capacitor that we have all used for years. The 011-408474 is "flatter" and thus leaves more room when nestled beside the coil winding. ,,,"
Re: Coil capacitors
Post by Scott_Conger » Sat Mar 14, 2020 11:14 am
Either one pictured works fine. The one on the left generally requires the glass partition to be removed in order to fit. A little more work, but that's all. Buy and use with confidence.
NealW
First Name: Neal
Last Name: Willford
Re: Coil capacitors
Post by NealW » Sat Mar 14, 2020 5:30 pm
Yep, that's what I had to do on the one "Ford" coil that I rebuilt a month or so ago. It was interesting to see the old, big condenser that got replaced with the orange capacitor. The others that I rebuilt were 1961 K-W's that had a smaller capacitor.
Scott C.
Last Name: Clements
Re: Coil capacitors
Post by Scott C. » Sat Mar 14, 2020 5:58 pm
I recently rebuilt a coil that had a normal points distributor type condenser in it. It was running and working fine in my 26 coupe. I should have posted a picture of it. The only capacitor that I have used, has been the thin rectangular ones from Lang's.
Ron Patterson
Re: Coil capacitors
Post by Ron Patterson » Sat Mar 14, 2020 6:14 pm
I have been rebuilding Model T Ford ignition coils for over 30 Years.
I kept examples of the range of various replacement capacitors I found inside.
Many .047 U Farad caps, Metalized Mylar and electrolytics.
I seems that some felt size was the most important criteria when in reality the DV/DT rating was the critical factor.
Here is a picture of that archive.
Another funny thing is I found was rocks, gravel, body putty, newspaper, silicone spray foam and, believe it or not, cement used as re-potting material.
Ron Patterson
Capacitor Archive 001.JPG (43.9 KiB) Viewed 8114 times
JohnH
Last Name: Hunter
Re: Coil capacitors
Post by JohnH » Sat Mar 14, 2020 6:28 pm
Ron Patterson
Just done a set of coils and found cotton waste as the 'potting' material.
Re: Coil capacitors
Post by DHort » Sat Mar 14, 2020 10:13 pm
Ron,
That would make a good display at the museum. Don't forget the rocks.
