Headlight assembly question
Wayfarer
First Name: Cory
Last Name: Woerth
* REQUIRED* Type and Year of Model Ts owned: 26 engine on a stand, Canadian '23 center door
Post by Wayfarer » Fri Mar 20, 2020 5:06 pm
I looked around and couldn’t find the answer - which direction does the chrome socket go ? The adjuster screw tab is not centered in the length, so does it go short side in the bucket, or long side in the bucket ?
Re: Headlight assembly question
Post by Scott_Conger » Fri Mar 20, 2020 5:15 pm
Longer slots toward bulb (and tab offset toward bulb)
You appear to have it correctly aligned with your 3 parts.
Be sure to check the screw for a cotterpin hole. Some don't come that way or at least didn't, so if necessary, drill the screw first, and cotterpin it after focusing...the repro screws unfortunately do not always come with the proper hole.
Wayfarer
First Name: Cory
Last Name: Woerth
Post by Wayfarer » Fri Mar 20, 2020 6:16 pm
you're right. no holes.
this could be fun... :lol:
EDIT: that was MUCH easier than expected ! I didn't even break a drill bit in the process !
Post by Scott_Conger » Fri Mar 20, 2020 6:42 pm
Excellent news!
Wayfarer
First Name: Cory
Last Name: Woerth
Post by Wayfarer » Fri Mar 20, 2020 8:26 pm
She has eyes !
