What is this tool?
Billy Vrana
Topic author - Posts: 109
- First Name: Billy
- Last Name: Vrana
- * REQUIRED* Type and Year of Model Ts owned: '25 homemade pickup, Fond Du Lac conversion tractor
What is this tool?
A friend sent this picture. What was it used for?
Herb Iffrig
- First Name: Herb
- Last Name: Iffrig
Re: What is this tool?
That is for drilling with a brace and bit by hand. It lets you get more pressure by wrapping the chain around what you are drilling and making more pressure by turning the threaded part.
StanHowe
- First Name: Stan
- Last Name: Howe
Herb beat me to it!
StanHowe
- First Name: Stan
- Last Name: Howe
Herb beat me to it! Most of these were used for drilling with a metal bit into a piece of bar stock or pipe when away from the post drill in the blacksmith shop. If you have ever tried to drill a hole in metal with a brace and bit you would appreciate this tool adding pressure while you were smearing lard on the hole and cranking on the brace.
Billy Vrana
- First Name: Billy
- Last Name: Vrana
Thanks for the info, I'll pass it along. This forum is great,
