reground cam 270 valve settings
mike37 cdn
First Name: mike
Last Name: mclean
Post by mike37 cdn » Thu Feb 07, 2019 2:51 pm
hi I have the engine out of my 26 coupe when I rebuilt it last year I put in a reground 270 cam I did not get the power increase I thought I might see I set the valves at 18 as per the shop I got it from has any body tried different setting at all if so what did you set them at and how did it run I have hc pistons in the new rebuild thanks mike
George N Lake Ozark
First Name: George P
Last Name: Clipner
Re: reground cam 270 valve settings
Post by George N Lake Ozark » Thu Feb 07, 2019 4:11 pm
!8 is too much. I'd shoot for 10/12. that's what's recommended for Stipe cams .
Post by Scott_Conger » Thu Feb 07, 2019 6:40 pm
For starters, I would find out who reground the cam and ask them what the gap should be. Simply picking a number will change valve events ever so slightly. Specifically, going wide will increase valve noise, retard valve events and reduce valve lift.
As far as power, you have an all steel, heavier car (but certainly not the heaviest made) and an engine that on it's best day in 1926 would likely produce less than 18HP at the tires based on many recent Dyno tests at National meets. In fact many stock cars log in around 14-18HP, even with fresh engines. A high lift cam will help increase HP but understand that it will be an increase of a fraction of 14-18 HP particularly if your compression is still stock. A high compression head should make you feel a difference if you were to add it. I suspect you are 1/2 way toward where you want to be. Best of luck, and welcome.
JWalters
First Name: Jason
Last Name: Walters
Post by JWalters » Thu Feb 07, 2019 6:52 pm
Mike has high compression pistons and can't add a HC head without changing pistons first.
Post by Scott_Conger » Thu Feb 07, 2019 7:33 pm
You're right. My mistake. That was one long sentence, and my eyeballs missed "hc" completely. That combination should give a decent pep in it's step unless the carb is shot or the intake manifold has a leak.
Steve Hughes
Last Name: Hughes
* REQUIRED* Type and Year of Model Ts owned: 1926 Touring 1921 Centerdoor
Post by Steve Hughes » Thu Feb 07, 2019 10:47 pm
I am currently building an engine for my '21 centerdoor. I got a 270 lift driver reground cam from Chaffin's Garage. They recommend .015" for both intake and exhaust. Since that is their recommendation, that is where I will be setting mine.
mike37 cdn
First Name: mike
Last Name: mclean
Post by mike37 cdn » Sat Feb 09, 2019 10:37 pm
any more in put on this one any one
