foam filled tires
bobt
Last Name: Thompson
foam filled tires
Post by bobt » Wed Apr 08, 2020 5:53 am
Hello. I have a 1915 touring that I purchased last August and have been enjoying the car and go for daily drives. The gentleman I bought it from told me I would never have to worry about the tires because they are foam filled. Well it has a set of nice Coker clenchers on it and they stay up but the ride like steel wheels. I have the painted demountable wood spoke with fellow wheels. I ordered a set of Firestone's with flaps and new tubes. My question is, Has anybody out there ever dealt with foam filled tires? Is the foam contained in the inner tube? Can I salvage the old tires or will I have to cut them off? Thanks, bobt
Plankhill
First Name: Brendan
Last Name: Doughty
* REQUIRED* Type and Year of Model Ts owned: 16 , 21, 24, Touring , 24 Roadster, 26 Speedster
Re: foam filled tires
Post by Plankhill » Wed Apr 08, 2020 6:38 am
I ran a set for several thousand miles. The ones I had ran pretty good. I would do it again if the price had not gone way up. The tube is filled with foam. No, you cannot save the tires. Take a Sawzall to them to get them off.
mtntee20
First Name: Terry & Sharon
Last Name: Miller
Post by mtntee20 » Wed Apr 08, 2020 7:43 am
+1 on using a sawzall to remove them. Remove the tube valve core just to be sure they are actually foam filled. Then be careful NOT to hit the rims when you saw. I might or might not have to cut them twice to get the off of the rim. They may be too stiff to get off with just one cut. Hopefully, you'll get lucky and one cut will work just fine. The good thing about foam filled tubes; you don't have to clean foam off of the rim before you can put your new tires on.
Good Luck,
Terry
Post by Scott_Conger » Wed Apr 08, 2020 10:17 am
And just when I thought I'd seen or heard everything...
Les Schubert
First Name: Les
Last Name: Schubert
Post by Les Schubert » Wed Apr 08, 2020 10:27 am
It’s a popular approach to forklift tires!!
tom_strickling
Last Name: Strickling
* REQUIRED* Type and Year of Model Ts owned: 11 Torpedo, 18 Touring, 21 TT Huckster, 24 Roadster,snowmobile, Shaw tractor conversion
Post by tom_strickling » Wed Apr 08, 2020 9:54 pm
I have heard that sometimes car museum displays use foam filled tires to cut out the maintenance issue of keeping tires full of air.
halftracknut
First Name: randy
Last Name: lee
* REQUIRED* Type and Year of Model Ts owned: 1926 pickup
Post by halftracknut » Thu Apr 09, 2020 10:57 am
I am up for it where to you call?
Post by DanTreace » Thu Apr 09, 2020 11:04 am
Back in the day, just go to your local auto parts supplier.
Pack 'em in.
Today, do it your self, grab some foam swim noodle floats and cut them up and stuff. :lol:
Last Name: Hatch
Post by Dan Hatch » Thu Apr 09, 2020 11:13 am
Be careful if you are thinking about doing this.
1. At one time was not approved for on road use. Do not know now.
2. If who ever does this does not get 100% of the air out of tire, there will be “air pockets” where no foam is. This will let the tire come apart and destroy it self. Removing the air was done by sticking a big needle in the tire sidewall so air could escape. Not sure how done now.
Hope this helped. Dan
Chris Instness
First Name: Christopher
Last Name: Instness
Post by Chris Instness » Thu Apr 09, 2020 11:17 am
Might not be a bad idea for that spare tire that always seems to be low on air when you need it.
Post by DanTreace » Thu Apr 09, 2020 3:01 pm
Dan
Just checked DOT and rules don’t forbid foam specifically, but guidance says materials other than air could be against rule if these materials affect tire performance. Maybe too an insurance liability issue to use anything other than what the pneumatic tire mfg. recommends.
Tim Moore
First Name: TIMOTHY
Last Name: MOORE
* REQUIRED* Type and Year of Model Ts owned: As many as can fit in the buildings, need to add on again.
Post by Tim Moore » Thu Apr 09, 2020 4:13 pm
I have a set of Stranger wire wheels that came off a T that was used for mail delivery. The tires were solid rubber without the normal holes going horizontal like sometime seen on ton trucks, looked like normal tires. I took them off with a sawzall and it took a LONG time!
This last fall I grabbed the wheelbarrow and as always the tire was flat. I pulled the tube out and drilled ,4 holes right in the center of the tread. 2 cans of expanding foam made a mess but it won't go flat again!
Tim Moore
Tim Moore
First Name: TIMOTHY
Last Name: MOORE
Spranger wheels, auto-correct on phone.
Speedster Jeff
* REQUIRED* Type and Year of Model Ts owned: 1923 Model T Ford Speedster
Post by Speedster Jeff » Fri Apr 10, 2020 10:30 am
Tim Moore
That is a great idea. Can it actually haul the amount of weight it is rated for, or does it squish down and then the tire is loose on the rim and foam?
Post by Scott_Conger » Fri Apr 10, 2020 10:51 am
And yet another really bad idea grows legs and takes off... :(
Speedster Jeff
Post by Speedster Jeff » Fri Apr 10, 2020 11:01 am
For use on my wheelbarrow? I wouldn't do it on a car.
Tim Moore
First Name: TIMOTHY
Last Name: MOORE
Post by Tim Moore » Fri Apr 10, 2020 12:17 pm
So far no trouble. I just push it around the yard so don't expect the foam to break down soon. Actually that expanding foam gets hard. When I first did this I figured it didn't work I would go to harbor freight and buy a solid tire. For some reason my wheelbarrow tires have never held air.
Post by Scott_Conger » Fri Apr 10, 2020 4:31 pm
certainly not on a wheelbarrow, no.
