Magnet Eater Coming Back To Life
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Thu Feb 07, 2019 9:04 pm
Making progress while fighting the flu, YICK!
Ruxstel24
Last Name: Hanlon
Re: Magnet Eater Coming Back To Life
Post by Ruxstel24 » Thu Feb 07, 2019 9:13 pm
I see the magnet is staying outside for the ride now. :D
havnfun
First Name: Joe
Last Name: Kowalczyk
Post by havnfun » Thu Feb 07, 2019 9:40 pm
Hank,
That's one beautiful T, congrats on getting your project this far along so fast, and sorry bout the FLU BUG, maybe a little spray of RAID in your shop will help.
Joe
Regards,
Marv K
First Name: Marv
Last Name: Konrad
* REQUIRED* Type and Year of Model Ts owned: '26 TT Steel Cab ("ToyBox Twoo"), '25 Coupe ("Cranky")
Board Member Since: 2010
Post by Marv K » Fri Feb 08, 2019 12:17 am
-Hank-
Flu bug or not, there are many of us 'green with envy'!
Among the many visual details, that dual exhaust set-up is extraordinary!! Could you please tell us more about it?
"Let's Figgur it owt!" Just fix it (right), and make it work.....
Aah-OO-Gah! (and), "Happy T-ing!"
Bob McDaniel
First Name: Bob
Last Name: McDaniel
Post by Bob McDaniel » Fri Feb 08, 2019 1:20 am
Don't let the bug get the best of you, it might turn into the mess I am fighting.
The T is going to be better than before if that is even possible. I am not into speedsters but that would be fun to own and drive. I am going to make room in the barn now.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Feb 08, 2019 9:09 am
The dual exhaust does work well with the higher lift cam, high compression head, and higher volume intake manifold. Having the split does give them a unique tone firing on the 1 and 4 on one pipe, and 2 and 3 on the other. Will keep you folks informed with pics as I progress. Using header pipe (no kinks at bending) gives a clean progression and no restrictions. Just therapy! I volunteered myself in helping Dave Carnahan in California in fabricating a custom header for his speedster, Will keep you folks posted on it as well. He is an ex Air Force Brother so do the math.
Doug Keppler was able to get me some of those automatic Ford transmission magnets for putting on the top of the cover, Thanks Doug! A little experimenting appears this is the ticket for me. Sure do not want anyone to go through what happened to mine.
All the Best,
Hank in Tin-A-See
RustyFords
First Name: Don
Last Name: Allen
Post by RustyFords » Fri Feb 08, 2019 1:42 pm
My goodness that's pretty Hank.
I'd love to hear the exhaust note if you have a recording of it.
1924 Touring
Post by Allan » Fri Feb 08, 2019 5:15 pm
Hank, that mounting method for the mufflers is a stroke of genius. Very neat . How will you make the pipes before the mufflers removable if needed? The two parallel pipes heading downwards from the manifold reminded me of the way the the problem was treated on the east-west motors in the Mini Coopers of the 60's. The headers at the back of the motor were terminated where they were straight and the pipes to the rear were sleeved to go over those straight sections. That gave a flexible joint which was needed to allow the motor to rock front to back as power was applied. There were no clamps on this sliding joint. In your application, it would allow the system to be taken apart for easy removal.
I mention this because I once had to rebuild a Ruckstel in a 1927 roadster which had as many accessories on it as could be fitted. The exhaust system had been custom fabricated to go around all sorts of stuff, and the only way I could remove it was to cut it into three pieces, and then make two slip joints to be able to re-instal it.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Feb 08, 2019 5:43 pm
Thank You to All for the kind comments, you all inspire me as well!
By loosening the mufflers, you can slide them back about 2 1/2”, remove the four retaining
nuts and washers, Down she comes. I like making things user friendly for the oh no factor.
All the Best,
Hank in Tin-A-See
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Fri Feb 08, 2019 5:53 pm
Just some more info, TSC offers a wide variety of generic tractor mufflers. But I do a google search and normally save another 30%.
Kaiser
First Name: Leo
Last Name: van Stirum
Post by Kaiser » Sat Feb 09, 2019 12:38 pm
Sweeeet !
Leo van Stirum, Netherlands
John Warren
Last Name: Warren
Post by John Warren » Mon Feb 11, 2019 11:00 pm
Henry, Great looking car, hope all is well.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Feb 13, 2019 6:26 pm
Well, A good day! she's back up and running stronger than ever!/Users/Lee/Desktop/IMG_0917.m4v
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Feb 13, 2019 6:29 pm
/Users/Lee/Desktop/IMG_0919.jpg/Users/Lee/Desktop/IMG_0920.jpg/Users/Lee/Desktop/IMG_0921.jpg
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Feb 13, 2019 6:31 pm
Lets try this again.
John Warren
Last Name: Warren
Post by John Warren » Wed Feb 13, 2019 7:56 pm
Great news, Thanks for the update. It sure is a beauty.
Michael Peternell
First Name: Michael
Last Name: Peternell
Post by Michael Peternell » Wed Feb 13, 2019 8:51 pm
Mr. Lee, heavy on the mister! You've taken the speedster build to an artistic level! Too cool for words.
GEmering
First Name: Gene
Last Name: Emering
* REQUIRED* Type and Year of Model Ts owned: 1913 Touring and 1924 Touring
Post by GEmering » Wed Feb 13, 2019 10:12 pm
Amazing workmanship!
Gene Emering
Newton, New Jersey
Bob McDaniel
First Name: Bob
Last Name: McDaniel
Post by Bob McDaniel » Wed Feb 13, 2019 10:53 pm
When do we get to hear it running?
gcomo
First Name: Gary
Last Name: Como
Post by gcomo » Thu Feb 14, 2019 6:54 am
Lookin good!!
havnfun
First Name: Joe
Post by havnfun » Thu Feb 14, 2019 9:42 am
Here is a link to Hank's magnet eater running again, enjoy, she sounds great...
https://www.facebook.com/10000839598335 ... 194859958/
Regards,
