More "modern" steering column
Matt_A_1926
First Name: Matt
Last Name: Atchinson
Post by Matt_A_1926 » Tue Apr 14, 2020 10:04 pm
Hey guys. So I've started assembling a 27 roadster gowjob/speedster. The T motor is just about squared away. I'm looking at setting up steering soon. Pop has a couple T columns, but also some A columns. I'm playing with the idea of a 30s Ford steering column to give a less sensitive steering for speedster speeds. Can one use an A column? I believe I heard once as well that a later 30s Ford column also fits in nicely.
David Mazza
First Name: David
Last Name: Mazza
* REQUIRED* Type and Year of Model Ts owned: 1925 t runabout
Re: More "modern" steering column
Post by David Mazza » Wed Apr 15, 2020 3:46 am
Model a steering
David Mazza
First Name: David
Last Name: Mazza
Post by David Mazza » Wed Apr 15, 2020 3:47 am
One more good detail
Chad_Marcheese
First Name: Chad
Last Name: Marcheese
* REQUIRED* Type and Year of Model Ts owned: 1925 Cut Off Touring / Pickup, 1923 Speedster Gow Job
Post by Chad_Marcheese » Wed Apr 15, 2020 6:23 am
You can search for mine I started building, or look on the HAMB forum Model T Gow Job. I too am running an A box...the better '30-31 box. Link: https://www.jalopyjournal.com/forum/thr ... b.1122709/
Interesting that the above pictures, that the end of the A box has been trimmed and turned down to fit in the clamping bracket, yet for some odd reason they still are running wedges on the clamping bracket. Really no need to do both.
Post by Mark Gregush » Wed Apr 15, 2020 10:39 am
David that is a nice clean job on installing. Chad, what do you mean by wedges?
Matt_A_1926
First Name: Matt
Post by Matt_A_1926 » Wed Apr 15, 2020 11:23 am
Good looking setup. It looks like I'd have to run the roadster with no sides of the hood though. Hmm, hadn't thought about that.
TeveS-Nor Cal
Last Name: Straw
Post by TeveS-Nor Cal » Wed Apr 15, 2020 12:21 pm
A lot of the GO JOBS used early Chevy boxes
Chad_Marcheese
First Name: Chad
Post by Chad_Marcheese » Wed Apr 15, 2020 8:05 pm
Edit: Knew I should have kept my mouth shut.....Later Y'all
Last edited by Chad_Marcheese on Wed Apr 15, 2020 8:31 pm, edited 3 times in total.
First Name: Henry
Last Name: Lee
Post by Henry K. Lee » Wed Apr 15, 2020 8:25 pm
That lower strap steel bar is used to dissipate the pressure from the u-bolts equally so not to cause shear.
Hope this Helps,
Hank
