I am looking for suggestions for direct replacement 6 volt LED bulbs for Tail lights and period correct turn signals. These are single contact and double contact parallel pin bulbs. I have found numerous 12 volt versions in both white and red for less than $2 each but still looking for 6 volt versions.
Any suggestions?
Source for 6 Volt LED Bulbs (not Headlight)
DontKnowMuch
Topic author - Posts: 209
- Last Name: Sanford
- * REQUIRED* Type and Year of Model Ts owned: 14 Touring, 26 Roadster, 27 Roadster
Re: Source for 6 Volt LED Bulbs (not Headlight)
Try this place;
https://www.ledlight.com/6-volt-negativ ... ights.aspx
Look for ones that are rated in the 6 volts range. Many on this site are not polarity sensitive. I would stay away from any that are rated, say 0-36 volts, they don't seem to be bright at the lower voltages. These would be best powered by battery not magneto (AC verse DC).
To add; other thing is to watch the base size, some fit better in the standard socket some do not. Color; The web site I posted suggest using the same color bulb as your lens, red lens red bulb etc.
Jim_PTC_GA
- Last Name: Fisher
- * REQUIRED* Type and Year of Model Ts owned: 1924, 1925-ish
This is something I will be hunting for when I get to the rewiring of my delivery/hack. Just a quick search on Amazon.com turned up quite a few results.
https://www.amazon.com/s?k=6+volt+led+b ... nb_sb_noss
I've never used any of these but it gives me hope that they are listed.
Jim
Jim
Just give me time to Rust and I'll be good as new.
Wabi-Sabi
