Exhaust Manifold Running Red
Rich Huggins
First Name: Rich
Last Name: Huggins
* REQUIRED* Type and Year of Model Ts owned: 1923 touring- 1922 deverley truck -1922 center door
Post by Rich Huggins » Fri Apr 24, 2020 8:19 pm
Hi my exhaust manifold runs bright red while driving, i smelled something burning ! oh no my floor board is on fire. Luckily i had water, burnt half way through the 3 piece floor board covered it with a sheet metal heat shield. I did drive home with no floor boards ,dam that was hot on the feet is this normal
Sunnybrook Farm
First Name: Gill
Last Name: Pollard
* REQUIRED* Type and Year of Model Ts owned: 26 parts
Re: Exhaust Manifold Running Red
Post by Sunnybrook Farm » Fri Apr 24, 2020 8:23 pm
Where are you running your spark lever? Sounds like timing may be retarded some how.
HPetrino
First Name: Henry
Last Name: Petrino
* REQUIRED* Type and Year of Model Ts owned: 1918 TT
Post by HPetrino » Fri Apr 24, 2020 8:53 pm
The usual suspects are either the spark is too retarded or the carburetor mixture is too lean, or a little of both.
Rich Huggins
First Name: Rich
Last Name: Huggins
Post by Rich Huggins » Fri Apr 24, 2020 9:22 pm
At low idle 1/8 to 1/4 on the spark rod adjust carb rich to lean then back to good idle just sitting with the garage fan on at high speed, manifold Cherie red! Driving 3/4 to 1/2 on the throttle 1/2 to 3/4 on the spark, no intake or exhaust leak at 1/2 to 3/4 on the throttle, the carb whistles like it wants more air and fuel small 23 holley nh carb
Post by Scott_Conger » Fri Apr 24, 2020 10:19 pm
It really doesn't matter where you "run the spark lever" if the timing is completely wrong, and it sounds like it may be completely wrong. I have never heard a T carb whistle that didn't have some sort of vacuum leak in the intake system. You really need to check both out as your car will not last long being run as it is, without requiring significant and expensive repairs.
Been Here Before
First Name: George John
Last Name: Drobnock
Post by Been Here Before » Sat Apr 25, 2020 9:47 am
Interesting that the question of coloured exhaust manifolds come up on occasion. May I suggest that a review of an training manual from WWII be reviewed. It may help with the manifold colours and the flames. (exhaust colour Allison V-1710)
