Gentlemen,
I’m learning about every aspect of the T, starting with the fundamentals which seem so basic to you all but are new to me.
A section of a book I’m reading discusses how to adjust the fuel mixture of the carb with the knob which comes though the firewall. It says, “A rich mixture is indicated by a heavy black exhaust smoke having a disagreeable smell. When this condition is manifested the needle valve regulator on the dash should be screwed down or to the right until the engine begins to misfire, then the gasoline feed is gradually increased by opening the needle valve in the other direction slowly to the point where the motor runs steadily and at a high rate of speed with a full throttle opening, at the same time, there being no evidence of smoke in the exhaust.”
Does that sound good to y’all? Or does anyone have some different guidance?
Thank you for your time,
Darin
13T - Carburetor Adjustment
Darin Hull
Topic author - Posts: 257
- First Name: Darin
- Last Name: Hull
- * REQUIRED* Type and Year of Model Ts owned: 1913 Model T & 1926 Model T project
- Board Member Since: 2010
Re: 13T - Carburetor Adjustment
Nothing's changed in 95 years.
Welcome to the affliction.
Bill Robinson
- First Name: Bill
- Last Name: Robinson
- * REQUIRED* Type and Year of Model Ts owned: '21 Depot Hack, '25 Touring Car, '26 Roadster Pickup, '27 Tudor, & another '27 Tudor
Sounds good to me. That’s how it’s done.
A good starting point is to gently screw the adjustment down until it seats, and then open it 1 1/2 turns.
The Ford Owner's Manual is a useful resource too. Vendors supply reprint of these.
And setting for initial starting of a fresh rebuild of the popular Holley NH, where the needle valve is new and new seat, these positions have worked the best IMO.
Darin, the sweet spot can be approached from the lean side or the rich side. I like to wind the needle in, [lean] until the car runs poorly. Then note how many turns it takes in the opposite direction to again have the car run poorly [too rich]. Then wind the needle down again 1/2 as much as you wound it out. That way you approach the sweet spot from the rich side. I reckon that is preferable to being on the lean side.
