Support Forum
Ruxstel24
- Last Name: Hanlon
Post
by Ruxstel24 » Sun Apr 26, 2020 5:54 pm
My friend Medina Bill made this.
Just a watzit, but I suggested putting something in it....firewater maybe ?
I like it, what would you put inside ?
kelly mt
- Last Name: Kelly
Post
by kelly mt » Sun Apr 26, 2020 5:56 pm
Stop leak.
Ruxstel24
- Last Name: Hanlon
Post
by Ruxstel24 » Sun Apr 26, 2020 6:01 pm
kelly mt wrote: ↑Sun Apr 26, 2020 5:56 pm
Stop leak.
What kind, the silver powder or pepper corns ?
- First Name: Dallas
- Last Name: Landers
Post
by Dallas Landers » Sun Apr 26, 2020 6:22 pm
MMO ! Purdy and usefull.
Mustang1964s
- Last Name: Bourgeois
- * REQUIRED* Type and Year of Model Ts owned: 1914, 1926, 1927
Post
by Mustang1964s » Sun Apr 26, 2020 6:35 pm
How hot does it get?
This would start limiting the possibilities.
Some blood red water would make folks do a double take.
dobro1956
- First Name: Donnie
- Last Name: Brown
Post
by dobro1956 » Sun Apr 26, 2020 6:51 pm
I agree with Dallas. Marvel Mystery Oil is always good for a conversation .... Add a small Marvel Mystery Oil decal to the glass for more fun things to talk about.
dobro1956 on Sun Apr 26, 2020 6:53 pm, edited 1 time in total.
- First Name: Dennis
- Last Name: Seth
Post
by perry kete » Sun Apr 26, 2020 6:51 pm
A couple of Goldfish.
Poppie
- First Name: Neil
- Last Name: Martin
Post
by Poppie » Sun Apr 26, 2020 7:03 pm
perry kete,
Tropical I hope...N.
George N Lake Ozark
- First Name: George P
- Last Name: Clipner
Post
by George N Lake Ozark » Sun Apr 26, 2020 9:14 pm
Era correct coffee percolator.
Post
by TRDxB2 » Sun Apr 26, 2020 9:42 pm
Lava Lamp Fluid - mostly water, oil ad some food coloring. The heat from the radiator may cause it to react.
- First Name: Henry
- Last Name: Lee
Post
by Henry K. Lee » Sun Apr 26, 2020 9:44 pm
Bunch of Hippies!!!!!
HPetrino
- First Name: Henry
- Last Name: Petrino
Post
by HPetrino » Sun Apr 26, 2020 10:21 pm
I agree with the fish idea. It would work like a manifold cooker, only with steam. Fish dinner when you arrive at your destination.
Post
by Mark Gregush » Mon Apr 27, 2020 12:56 am
I was think about the fish but would go with their little white bleached skeletons floating around inside. Maybe those balls they use in water thermometers.
https://www.zmescience.com/other/featur ... ter-03213/
- Last Name: Patrick
Post
by jiminbartow » Mon Apr 27, 2020 1:02 am
Nice! Looks like an old fashioned glass gasoline pump reservoir. I would put in some water colored with green and red food dye to resemble the reddish brown color of gasoline and put a “Texaco” decal on it. Bourbon or tea with a little red food dye would work as well. Jim Patrick
Post
by TRDxB2 » Mon Apr 27, 2020 2:22 am
Couple of these floating around
Charlie B in N.J.
- First Name: CHARLIE
- Last Name: BRANCA
- Board Member Since: 2010
Post
by Charlie B in N.J. » Mon Apr 27, 2020 6:02 am
I was thinkng coffee grinds but that would cause too many questions to be asked. MMO sounds about right. Finally something it's good for.
Jim_PTC_GA
- Last Name: Fisher
- * REQUIRED* Type and Year of Model Ts owned: 1924, 1925-ish
Post
by Jim_PTC_GA » Mon Apr 27, 2020 6:19 am
I like the idea of the tiny rubber duck on water but I would fill it with mannequin fingers to symbolize all the smashed fingers I've had restoring the T.
Just give me time to Rust and I'll be good as new.
Wabi-Sabi
Ruxstel24
- Last Name: Hanlon
Post
by Ruxstel24 » Mon Apr 27, 2020 7:54 am
LMAO !!
How bout a little oil and some popcorn ?
If the T gets too hot, the popcorn pops and you pull over and have a snack while she cools off.
RalphS
- First Name: Ralph
- Last Name: Sullender
- * REQUIRED* Type and Year of Model Ts owned: 21 tt
Post
by RalphS » Mon Apr 27, 2020 10:47 am
A bit of HOT salsa to go on the burritos warming in your manifold cooker !
Around and around we go and where we stop we check the gas oil water and tires.
StanHowe
- First Name: Stan
- Last Name: Howe
Post
by StanHowe » Mon Apr 27, 2020 11:33 am
Probably a little roll of solder because that much weight will break the radiator neck loose.
I assume you know it's a drip oiler.
Looks cool, I would put something that would fizz and make a decal that said, "Dr Fitt's Stay Cool for Fords" or something like that.
RichardG
- Last Name: Grzegorowicz
- * REQUIRED* Type and Year of Model Ts owned: 1921 T pickup
Post
by RichardG » Mon Apr 27, 2020 11:59 am
THAT'S A GREAT IDEA, THE DUCK I THINK WOULD BE PERFECT, A FEW YEARS BACK I RESTORED A M-D- INTERNATIONAL TRACTOR, I PUT A MODEL OF A JOHN DEERE IN THE GLASS AIR FILTER, IT WAS MOST A YEAR BEFORE IT WAS FOUND, NOW I SEE THEM A LOT AT THE SHOWS. GOTTA HAVE SOME FUN ONCE IN A WHILE.
Post
by Mark Gregush » Mon Apr 27, 2020 12:01 pm
That would be a good way to say that M-D- INTERNATIONAL left John Deer behind in the dust.
Post
by Dallas Landers » Mon Apr 27, 2020 4:27 pm
Put little blue ford ovals in it and say its giving birth to baby fords.
RxGPoblet
- First Name: Garland E
- Last Name: Pobletts
- * REQUIRED* Type and Year of Model Ts owned: 1915 Model T Touring
Post
by RxGPoblet » Mon Apr 27, 2020 6:26 pm
Add an upper chamber and use it to brew coffee when you overheat. A nice cup to sip while you wait for it to cool down. No antifreeze.
Ruxstel24
- Last Name: Hanlon
Post
by Ruxstel24 » Tue Apr 28, 2020 5:55 pm
“Something fizzy...”
How about some Bromo Seltzer ?
Settle that burping radiator !!
Post
by TRDxB2 » Tue Apr 28, 2020 8:46 pm
Faux Ice cubes floating in mineral oil. Don't want anything to freeze
- A68CDD8E-8881-41AF-9925-3A73E742BF07.jpeg (35.97 KiB) Viewed 8555 times
