Support Forum
NHUSA
- First Name: Fred
- Last Name: Dimock
- * REQUIRED* Type and Year of Model Ts owned: 1919 T with Mifflinburg Suburban body
Post
by NHUSA » Tue Jan 08, 2019 12:24 pm
NH - Where I used to live - not the carburetor !
- Last Name: Strange
Post
by CudaMan » Tue Jan 08, 2019 12:25 pm
Well, it gives them whatever info you chose to put in your profile, no more.
yukonjack
- First Name: Jack
- Last Name: Murray
- * REQUIRED* Type and Year of Model Ts owned: 1926 light express
Post
by yukonjack » Tue Jan 08, 2019 12:54 pm
Try this:
Click on your user name on the upper right of the screen, and go down this rabbit hole: User Control Panel/Board Preferences/Edit Global Settings; on the Global Settings page there should be a category called Hide My Online Status, click yes and follow the instruction
ChrisB
- First Name: Chris
- Last Name: Brancaccio
- * REQUIRED* Type and Year of Model Ts owned: 1909 Roadster 1915 Coupelet 1923 Coupe 1926 Touring
Post
by ChrisB » Tue Jan 08, 2019 1:59 pm
Mark, I see you liked Steve J's Red Green picture!!!
You should change your user name to Duct Tape!
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
Post
by CudaMan » Tue Jan 08, 2019 2:06 pm
LOL!
By the way, my PM to Charley Shaver finally got sent (took over 1/2 hour to leave my out box).
Post
by Steve Jelf » Tue Jan 08, 2019 2:13 pm
Is that a fiber timing gear?
ChrisB
- First Name: Chris
Post
by ChrisB » Tue Jan 08, 2019 2:35 pm
Yes it was my first breakdown, home on a flatbed.
Chris Brancaccio
MTFCA Webmaster
MTFCA Forum Admin
GJScholz
- First Name: Gregory
- Last Name: Scholz
Post
by GJScholz » Tue Jan 08, 2019 2:57 pm
In the User Control Panel, Under Board Preferences, you can hide your on line session.
Hiding that will remove your name from that list at the bottom.
http://www.modeltfordclubofamerica.com ... .php?i=179
Will_Vanderburg
- First Name: William
- Last Name: Vanderburg
Post
by Will_Vanderburg » Tue Jan 08, 2019 4:36 pm
Why do or would people care if anyone knows they’re online or not? What are you trying to hide?
William L Vanderburg
1922 Center Door Sedan
