speedster dashes
scott hills
First Name: scott
Last Name: hills
* REQUIRED* Type and Year of Model Ts owned: 1924 Paco speedster 27 touring
Board Member Since: 2012
speedster dashes
Post by scott hills » Sun May 03, 2020 10:05 am
we have seen your wheels how about your dashboard
paco dash.jpg (26.8 KiB) Viewed 7057 times
paco dash 2.jpg (28.89 KiB) Viewed 7057 times
paco dash 3.jpg (25.02 KiB) Viewed 7057 times
Re: speedster dashes
Post by RajoRacer » Sun May 03, 2020 12:10 pm
Hey Scott - here's mine.
Post by Rich Eagle » Sun May 03, 2020 4:32 pm
What a great idea. Those are magnificent!
Here are mine.
spadpilot
First Name: David
Last Name: Carnahan
* REQUIRED* Type and Year of Model Ts owned: 1917 Speedster
Post by spadpilot » Mon May 04, 2020 12:49 pm
Here's mine....genuine Tennessee Black Walnut
...some people are like Slinkies....they're generally useless but fun to watch when you push them down the stairs.
kelly mt
Last Name: Kelly
Post by kelly mt » Mon May 04, 2020 3:39 pm
My dash is bare bones.
Kevin Pharis
First Name: Kevin
Last Name: Pharis
Post by Kevin Pharis » Mon May 04, 2020 5:48 pm
Here’s a shot of my blasphemous dash with its modern gauges (they do work good tho). I made the dash control panel to look like the ‘ol Delco units of the day, and the starter push button to match. All accept modern switches from the back side. Original Dixie mag switch serves as the main switch for he whole system
scott hills
First Name: scott
Last Name: hills
Post by scott hills » Tue May 05, 2020 12:34 am
I need to learn how to take better pictures your guys do way better hey (tomatoe) probably ben awhile since you've heard that surname but that was Kipplings go to for you get that speedster on a run won't call it a RAJO racer till I have a chance to pass you 😜
Luxford
First Name: Peter
Last Name: Kable
* REQUIRED* Type and Year of Model Ts owned: 1911 Town Car 1913 Speedster 1915 kampcar
Post by Luxford » Tue May 05, 2020 8:40 am
Here is the dash on my Speedster
Originally built by Speedster Hall of Fame inductee Vic Jacobs.
Post by TRDxB2 » Tue May 05, 2020 4:38 pm
Still planning and parts gathering. The dash is a 1926 Dodge, I liked the layout of the dash but more important is the top curve which I'm after for the body. Intending to add a SW water temp gauge in the open hole. Just got the switch and had to find a spacer (copper will nickle plate it later) to fill the gap. Will be using a REO face-plate when done.
Post by Scott_Conger » Tue May 05, 2020 4:53 pm
Frank
that is a great dash for a speedster
Post by RajoRacer » Tue May 05, 2020 7:57 pm
I sure miss "O Great Bald One" - Kipling !
tdump
First Name: Mack
Last Name: Cole
Post by tdump » Tue May 05, 2020 9:43 pm
I appreciate this thread.
1 thing I do know is going on the dash of my speedster, and that is some turn signal indicator bulbs BIG ENOUGH that I can see them!
The little tiny light in my turn signal switch on the T pickup is so tiny,and I don't see them under the steering wheel. If they were on the dash and big and bright, I would not ride around like a really old man,with my blinkers on!
I want a temp gauge and a clock and of all things a DRINK holder!
Yes I want a drink holder in my T speedster. I like to have a Dew with me and there is NO where on my pickup YET to put 1.
I am thinking maby finding a real old coffee can that is rusted and using it's outer shell and something accross the bottom. Or a Kings surup can.
Model T Tom
First Name: Thomas
Last Name: Butterworth
* REQUIRED* Type and Year of Model Ts owned: 1911 speedster
Post by Model T Tom » Wed May 06, 2020 6:13 am
This is the one I did for a 1911
Playswithbrass
First Name: Peter
Last Name: McIntyre
* REQUIRED* Type and Year of Model Ts owned: 1913 Speedster
Post by Playswithbrass » Wed May 06, 2020 6:46 pm
It’s a fuel pressure gauge
Post by TRDxB2 » Wed May 06, 2020 7:53 pm
Many variations GOOGLE gimbled drink holder Its a Nautical Item
Post by Wayne Sheldon » Thu May 07, 2020 3:24 am
I think a Campbell's Tomato soup can would be just about right!
AndyClary
First Name: Andrew
Last Name: Clary
Post by AndyClary » Thu May 07, 2020 3:09 pm
I’m guessing my dash has had a couple different layouts. I’ll be putting an overlay on when I get to it.
Andy
2nighthawks
First Name: Harold
Last Name: Schwendeman
Post by 2nighthawks » Thu May 07, 2020 3:27 pm
Frank - I think "auto-correct" played a trick on you as your post reads "gambled" when you meant "gimbled". In fact, the same think just happened to me from "auto-correct",.....changed my "gimbled" to "gambled",....in fact, it just did it again! I hate "auto-correct" as I have to remember to proofread to correct my "auto-correct" changes that I didn't want!
Post by TRDxB2 » Thu May 07, 2020 3:59 pm
I corrected it and then just did a submit and it kept gimbled - didn't happen this time :?
