Lettered pedal differences
Don ellis
First Name: Don
Last Name: Ellis
* REQUIRED* Type and Year of Model Ts owned: 1911,1917,23,27
Post by Don ellis » Thu May 07, 2020 12:16 pm
[image][/image]looking through my spare parts I noticed the difference in the style of the letter in this reverse pedal. I probably would have never thought about it I hadn’t had them lying next to each other. Does anyone know anything about the reason or is it just different manufacturers?
Re: Lettered pearl differences
Post by RajoRacer » Thu May 07, 2020 1:01 pm
The one on the right is peculiar - is there a cartouche on either ? DB, TW ?
Herb Iffrig
First Name: Herb
Last Name: Iffrig
Post by Herb Iffrig » Thu May 07, 2020 1:31 pm
Are there any differences at the other end?
Post by Rich Eagle » Thu May 07, 2020 2:13 pm
This is what you can buy today to weld on. It looks a little like the one on the right to me.
I would suspect molds changed back then as well as today.
Don ellis
First Name: Don
Last Name: Ellis
Re: Lettered pedal differences
Post by Don ellis » Thu May 07, 2020 7:25 pm
Well I see spellcheck got me again. One of these days I’ll learn to proofread.
I’m working at the fire station tonight, tomorrow I’ll check for makers marks.
Don ellis
First Name: Don
Last Name: Ellis
Post by Don ellis » Fri May 08, 2020 9:21 am
One is marked DB, the other just a part number.
This is the DB
Post by Original Smith » Fri May 08, 2020 10:33 am
I have an interesting one on my '13 roadster. The pyramid pattern on the clutch pedal is coarser than the other two pedals. I assume it's from the time when Ford was changing over from Dodge Bros. to his own production methods?
nsbrassnut
Last Name: Lee
Post by nsbrassnut » Sat May 09, 2020 6:50 pm
Here is one from Canada. RHD reverse pedal on my '15.
Marked DS, believed to stand for Dominion Stamping in Windsor, Ontario which started to make parts for Canadian Fords about 193/14
Drive Safe
Jeff
